Help identify diode!
Old 21st June 2018, 07:34 AM   #11
lineup is online now lineup  Sweden
lineup's Avatar
Originally Posted by Elvee View Post
It is definitely from Philips, thus from the body colour it is either a BAWxx or a BATxx.
Since it is a small body, it must be a BAT, and from the color code (gray/green), it is a BAT85, a small schottky diode.
The low voltage drop (0.5V) also indicates it is schottky diode.
BAT85 is a very good guess.
lineup
Old 21st June 2018, 09:15 AM   #12
lcsaszar is offline lcsaszar  Hungary
Is there any component symbol (white rectangle) or just a straight line under the diode? In the latter case just bridge it If there is no improvement, restore the original state
Old 21st June 2018, 03:21 PM   #13
hollowman is offline hollowman  United States
hollowman's Avatar
Default Huh?
Originally Posted by Mooly View Post
You could also use a normal diode to 'lift' the -5 volts to around -5.6 and see if that has any effect.
I'm limited to a MAX of -5v per the stock, factory-original 7905. See OP of this thread. Yes, the PDF schematic has a 7906, not 7905. But my Philips CD60 uses a 7905.
Also, in the other thread, I noted that I did replace the 1541's -5v rail 5-ohm "safety R" to 0.5-ohm. That brought the voltage up -4.5v (up from -4.3). Noise issue remains.
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 21st June 2018, 04:04 PM   #14
hollowman's Avatar
Default No improvement!
Straight, white line underneath (like jumpers).
Bridged it, which brought up Vdd1 to -4.9v.
Noise issue remains!
Old 21st June 2018, 04:25 PM   #15
leadbelly is online now leadbelly  Canada
leadbelly's Avatar
Let the diode go YouTube
Prove all things 1 Thessalonians 5:21
Old 21st June 2018, 05:19 PM   #16
Mooly's Avatar
Default Eh
Its a standard technique to lift the output a three terminal reg. This shows a 7805, the 7905 would have the diode fitted the other way around (remember the pin outs are different for 79 regs). Use a 1N4148 type diode (small signal type as only a tiny current flows in it). The reg output is raised by the forward voltage of the diode. It works well... and you can use zeners (6v8 or 7v1 Zener) to make for example a 12 volt reg using a 7805, or you can use a resistor/s and make it variable, or you can add a transistor to the ground lead and make a super adjustable regulator with terrific regulation.
Here is the simple way. This adds around 0.65 volts to the reg output.
Help identify diode!Hide this!Advertise here!
help me identify this diode please ampjunkielikeme Car Audio 3 4th April 2015 06:50 AM
Help to identify diode replacements Quixote Parts 6 10th November 2013 12:14 PM
Can you identify this (schottky?) diode? ric-paul Parts 5 3rd June 2013 10:33 PM
Need help identify the diode milen007 Parts 13 3rd January 2012 07:46 AM
help identify anode of this diode rectifier milen007 Parts 9 7th August 2008 04:13 AM
