PCB lay out and part list for a 5 volt linear PSU
Moderator
Joined 2011
If you let people know where you are then someone may be able to help you better.
For example, if you lived in the city where I am I would be able to supply you with something for a very reasonable price.
But you would still have to provide some more details. ( as rayma stated )
So, you will want a bridge rectifier using 5A+ diodes, a 2200uF filter cap (1500uF min ), a V7805-200, and an output filter on the 5V.
Datasheet on the V7805-2000 here:
https://www.cui.com/product/resource/v78xx-2000.pdf
Or you can use a linear regulator and dissipate about 5W in heat. There are a few of these around.
I do not think I have any regulator boards with integrated rectifier and filter caps but I will look.
