Purple LT3042 ebay / aliexpress
Old 13th June 2018, 01:41 PM   #1
hkknudsen is offline hkknudsen
Default Purple LT3042 ebay / aliexpress
These new purple LT3042 boards are spreading on aliexpress and ebay like a virus, and they are very cheap.
But do they look to be any good? Would all that is needed to change the output voltage be to replace one of the resistors?
File Type: png Screen Shot 2018-06-13 at 15.38.25.png (664.7 KB, 297 views)
Old 13th June 2018, 01:53 PM   #2
Mooly's Avatar
The output voltage is set via a single resistor on these. The data sheet gives details, and also describes the PGFB (power good feedback) which may or may not be used.
http://www.analog.com/media/en/techn...www.linear.com
Old 13th June 2018, 04:39 PM   #3
Thanks Mooly... my next doubt was if I am able to replace a smd resistor with a regular, but that seems possible (with my limited experience). And next is what others think of one that is that cheap (it's around half price of the usual offers).
Would I be right in assuming that I can get -10V, 0V, +10V from this one, by combining the 2 outputs at the 0V (can I be sure they're independent)?
Purple LT3042 ebay / aliexpress-screen-shot-2018-06-13-18-37-08-jpg
File Type: jpg Screen Shot 2018-06-13 at 18.37.08.jpg (104.3 KB, 511 views)
Old 13th June 2018, 05:59 PM   #4
Mooly's Avatar
Replacing an SMD resistor with a regular one is fine as long as its done neatly.
I don't think combining two PSU's as you describe would be very successful, not least because each would need a truly independent voltage source feeding them.
Old 13th June 2018, 06:11 PM   #5
Not sure if we're talking past each other, but the last one is dual from the beginning, so I'm just wondering if I can combine those 2 outputs to +, 0 and -, which seems to me to normally be possible. Its just for a preamp drawing only 2 x 20mA or so, so I would'nt think the outputs would effect each other much
Old 13th June 2018, 07:23 PM   #6
Mooly's Avatar
My mistake, I was thinking of you combining to regular PSU's although I'm afraid the answer is still the same.
The one in the link definitely will not work as -10 0 10 because both regulators share the same bridge rectifier and reservoir cap which means that they will also share the same ground. This means there can not be any isolation between them.
Old 13th June 2018, 07:33 PM   #7
Aha, thanks, very useful! But if I buy 2 single's instead it'll be fine?
Old 14th June 2018, 06:49 AM   #8
Mooly's Avatar
Only if you run each from a separate isolated transformer winding. They can not share the same source voltage.
The two supplies have to be 100% independent to allow series connection.
Old 14th June 2018, 09:04 AM   #9
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Is it possible that they use fake reg chips?
If I buy 2K X LT1963 from mouser, they cost around 3 dollars, so how do these guys sell this for a profit?
LT1963 Power Converter 12V to 5V DC DC Step Down Buck Power Supply Module-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 14th June 2018, 05:56 PM   #10
Excellent, I finally get it. I thought the regulator itself was somehow a decoupling layer.
Thanks for your help and patience Fortunately I use 2 independant secondaries.
I am also a bit worried about the authenticity from aliexpress/ebay. I know that opamps can't be trusted at all, but have no knowledge about regs.
Purple LT3042 ebay / aliexpressHide this!Advertise here!
cheap aliexpress/ebay ADAU1452 development boards usagi Digital Line Level 11 2nd June 2018 05:44 PM
LT3042 universal PSU PCB jean-paul Power Supplies 31 6th March 2018 09:13 AM
LT3042 uchu007 Parts 1 26th February 2018 04:43 AM
How to search for full rangers on Ebay or Aliexpress? leadbelly Full Range 10 18th April 2017 09:46 PM
Wanted: LM1036 tone board (no ebay or aliexpress board) schdrag Swap Meet 0 2nd December 2016 06:47 PM
