Symmetrical psu TPS7A4701
Power supply
Hi Fabrice,
I have done it - you need a transformer with 2 secondary windings (not a centre tapped transformer).
Connect one regulator to the first winding and the other regulator to the second winding - then connect the + output of one regulator to the ground of the other, you will now have a dual rail power supply.
