Applying GaN transistor as a replacement of SiC rectifier
Ideal diode bridge rectifier with GaN transistor and LT4320
The second pictue shows four GaN Transistors are used for 4-diode rectifier (bridge) configuration in the left side part. The right side part shows a conventional SiC diode set with Infineon Gen6 products.
Bunpei has replaced the 4-diode rectifier (bridge) circuit with “ideal diode type” 4-diode rectifier circuit prototyped by Mr. Hazawa.
LT4320+GS61008T(GaN)_組立編: アナログ回路のおもちゃ箱 (In Japanese)
Here is a picture of his meticulous prototype.
The prototype use one LT4320 driver chip and four GS61008T GaN E type transistors.
Bunpei could perceive a very positive SQ improvement after the replacement.
Bunpei would like to express sincere gratitude to Mr. Hazawa’s effort.
By Bunpei’s request, Mr. Hazawa in Tokyo designed and assembled a new PCB of “ideal diode type bridge (4-diode) rectifier. The PCB incorporates one LT4320 and four GS61008P GaN E-mode HEMT.
Bunpei will apply it to DC power supplies for his DACs by replacing existing Si diodes and SiC diode with it.
AC input must be 9-75V and a capacitor must be placed at an output.
a sigmadelta converter consists in it's simplest for of an integrator, followed by a clocked comparator, and a feedback path feeding back the digital representation at the output to the input to create a correction signal. the inegrator acts as "noise shaper" such that low frequency sampling noise is moved up to the higher frequency energies.
a power sigmadelta is the same structure, only the output logic is now + or - Vsupply, that could be like +/- 100V. that one needs fast and perfect switching, an ideal job for GaN.
why not use these for a power sigma-delta converter.
I’m sorry that I can’t catch the meaning of your words “why not”. Are you affirmative to apply GaN devices to a power delta-sigma converter?
What I reported on my post in Class D amplifier Forum is just “a power delta-sigma converter”. Are you negative to the application?
Anyway, in both applications, a rectifier for 60Hz and a switching device for 2.8 - 11.2 MHz delta-sigma modulated 1 bit audio signal(DSD), Mr. Ozawa and Bunpei perceive something very low-noise in its resultant sounds.
dear Bunpei,
I could not read from your description that the your GaN classD is actually a sigma delta converter with noise shaping. or said differently, measuring the power supply rfejection would reveal the difference.
I am a great fan of GaN. I use it for 6.78MHz classD power stages for wireless charging and active rectification. the very low gate drive requirements are a leap forward in active device technology. one caveat I found is that the gate capacitance has such a high Q, that any inductance in the gate path leads to ringing, such that always series resistors are needed.
I described as shown below, saying clearly a delta-sigma modulated 1 bit audio signal was directly input.
... The board assumes a PWM input signal of sampling frequency up to 400 kHz.
Bunpei thought, not only PWM but also PDM, namely delta-sigma modulated 1 bit signal (DSD) might be feasible because a gate driver device, PE29102 is operative up to 40 MHz and GaN E-mode HEMT GS61004B is operative up to 100 MHz.
He told his idea to Professor Yamasaki of Waseda University, who is a leader of 1 bit audio community in Japan. The professor immediately purchased the evaluation board and got a preliminary successful result with TASCAM DA-3000 as a 1 bit signal generator and YAMAHA NS-10M studio monitor as a speaker for 2.8 MHz delta-sigma modulated audio source. ...
Joined 2017
basreflex.
I can't understand your definition about DSM amplifier. One bit signal fed to an amplifier is already DSMed. Then 1-bit signal amplifier can be considered as powered DSM though it doesn't have delta-sigma modulator in itself. I can agree that bunpei's approach is not true classD, because classD generally accepts analog signal. But I can understand his project is DSM amplifier. I'm not familiar with classD. If I am wrong, please correct.
:cool:
Bunpei applied Mr.Hazawa’s LT4320 ideal diode driver board with GaN E-mode HEMT GS61008P to +5V DC power supplies for a master clocking circuit in Chiaki’s ES9038PRO Dual Mono DAC and for a bipolar transistor driver circuit in NDK DuCULoN OCXO. Original four bridge diodes were four G-S tied GS61008T
The resultant SQ improvement is very satisfactory though no apple-to-apple comparison was not made because of an unavoidable transformer configuration change associated.
