Power supply ground
Power supply ground
Old 4th February 2018, 09:26 AM   #11
emosms is offline emosms  Bulgaria
Some modification.
1. The multicontroller is isolated with optocouplers. Do we still need to connect the microcontroller ground (PSU1) to the other ground?
2. The spdif module gets +5v digital and ground from PSU2.
3. The DAC module gets:
- i2s data
- +5v digital and ground from the spdif module
- +5v analog and ground from PSU3
- +-15v bipolar and ground from PSU4
Here all the ground comes into common ground.
The problem is down to designing the DAC pcb.
All grounds on seporate poligons and a point of connection between them.
Possibly, option for ground potential elevation of any ground to any ground...
4. The analog input selector is ommited, since it is relays. Galvanically isolated.
5. The Xover module gets:
- audio signal from dac
- +-15v from dac
- common ground from dac
6. The vol control module gets:
- audio signals from Xover
- +-15v from Xover
- gnd from Xover
Moreover, it derives +5v (or whatever necessary) from the +15v, to feed the optocoupler and digital control.
Not very clean but... do we need a seporate PSU for this??
Is that OK architecture? Most of the interesting stuff happens in the DAC pcb and topology.
Old 4th February 2018, 01:05 PM   #12
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
No, but do you need separate PSUs for the different digital circuits? And why not have one supply for all the analogue circuits, derive the +5V from the +/-15V?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Power supply groundHide this!Advertise here!
Choke in power supply ground Nailbunny7 Power Supplies 20 1st June 2017 08:32 PM
OTL Power Supply: Halfwave vs Virtual Ground ballpencil Tubes / Valves 0 18th February 2014 02:24 AM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 05:17 PM
Floating ground power supply Theodore Julie Power Supplies 8 11th June 2007 10:54 PM
Power Supply Ground Confusion Dwiel Everything Else 11 24th June 2005 07:46 PM
