Off-The-Shelf Linear PS for Pi?
Old 4th February 2018, 04:43 PM   #11
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
A linear power supply is not inherently less noisy than a SMPS, there are good and poor ones of both kinds
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 4th February 2018, 04:47 PM   #12
BillTheCat is offline BillTheCat
Given the objective of maximizing the performance of a Pi-based DAC, would you say a good switching supply would do as well as an LPS?
I already have a couple of the Meanwell RS-15-5's on hand. Would you say this is adequate? Also, do you think this is enough to power both the Pi and the DAC, or should I use two?
Old 4th February 2018, 05:03 PM   #13
2 amp SMPSs are used with the Pi, what DAC are you using?
Old 4th February 2018, 05:05 PM   #14
HiFiBerry DAC+Pro XLR.
Old 4th February 2018, 05:21 PM   #15
One of the Meanwell power supplies will be fine, have you tried it, is it noisy? Have you means to measure noise if you can't hear any?
Old 4th February 2018, 06:29 PM   #16
R.I.P.
Originally Posted by BillTheCat View Post
Are these linear power supplies?
Sorry to say, I'm not even sure what this means. Seems there's some thinly veiled innuendo, but I'd be grateful if you can lead me to it. Perhaps you could just say what's really on your mind?
Members who are conversant with linear tend to stay with what they already know.
Members who are digital/switching tend to be more comfortable with what they already know.
You as a Pi specialist is already digital/switching. You already have switching PSUs. To me that means you know about switching so a switching PSU may be what you should use.
No innuendo, just common sense.
regards Andrew T.
Old 4th February 2018, 06:32 PM   #17
You as a Pi specialist is already digital/switching. To me that means you know about switching so a switching PSU may be what you should use.
I'm not sure where you got the idea I was a "Pi specialist". I'm nothing of the sort. And if I knew what I was *really* doing, I wouldn't be asking, now would I? Or, did you think I had nothing better to do than to invite all sorts of silliness in the form of comments?
Old 4th February 2018, 06:35 PM   #18
As I said in another thread, to do a proper analysis would entail multiple configured variants of Pi/DAC/PS/SD/Software assemblies to do a proper A/B/C/D... testing. That would also tie up four or five hundred dollars, when all I'm really after is just one. So I figured I'd just get right to it and ask from those of you who have likely already gone down this path.
Old 4th February 2018, 06:56 PM   #19
I'll take that as a "no"
Old 4th February 2018, 06:57 PM   #20
LOL. Yep. Well, actually, I am using the meanwell to power the DAC and the wall wart to power the Pi. But improvements are always welcome.
Off-The-Shelf Linear PS for Pi?Hide this!Advertise here!
CD shelf finnished jugi63 Everything Else 9 16th February 2015 01:53 PM
Best off the shelf amp CCU Chip Amps 2 29th November 2013 08:03 PM
shelf oscilating psu east electronics Power Supplies 9 22nd November 2012 12:57 AM
Off the shelf PCB Captn Dave Parts 6 15th February 2011 10:37 PM
shelf/mounting a TT dieselpower Analogue Source 2 25th January 2005 07:23 AM
