LM317/337 ripple/noise/oscillation
Old 1st February 2018, 07:10 AM   #11
dotneck335 is offline dotneck335  United States
I saw a study that recommended a load for three-pin regulators of 220uF, with ~100mΩ ESR; also 220uF across the voltage adjustment resistor. This provided the best noise and ripple characteristics. Also note that the Linear Technology LT317/337 regulators have definitely better datasheet specs than the typical T.I. LM317/337s----about 16db better ripple rejection and about 10db less noise. They're more expensive---about $2.50 each, while T.I.s are 50; but for DIY projects where you're only using a few, it's money well spent.
Old 1st February 2018, 07:18 AM   #12
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
What is the distance between the input pin (power) of LM317 and the 100nF ceramic?
And also the distance of output pin (power) of the LM317 and 100nF ceramic/220 electrolytic?
Old 1st February 2018, 07:25 AM   #13
belyakove is offline belyakove  Netherlands
Input ceramic sits almost right on the input leg of regulator and output capacitor is around 1.5-2cm away from the output leg. Here are several photos of the PSU board.
Old 1st February 2018, 08:45 AM   #14
The capacitor (ceramic/electrolytic) should be less than 1cm away from input pin of LM317.
The capacitor ceramic and electrolytic (470uF) should also less than 1cm away from the output pin of LM317.
Old 1st February 2018, 09:07 AM   #15
Can you post the PCB layout?
Old 1st February 2018, 09:48 AM   #16
Here's the PCB layout
Old 1st February 2018, 09:53 AM   #17
The layout is not correct.
Old 1st February 2018, 10:38 AM   #18
Can you please explain what is not correct here and how it can be improved? I'm pretty novice so trying to learn things.
Old 1st February 2018, 12:02 PM   #19
The distance from capacitor (PIN +) to PIN 3 of LM317 must be less than 1cm.
The same for PIN 2 (output PIN).
And you also add diodes (like 1N4001) from output to ground (anode to PIN 2)
And from output to input (anode to input (PIN3))
Have a look at the datasheet for that. Here: https://www.google.de/url?sa=t&rct=j...OPMAJjbmXwAgfV
Old 1st February 2018, 12:20 PM   #20
chip_mk is offline chip_mk  Macedonia
Originally Posted by belyakove View Post
Tried with 1k resistor (metal film if it's important) and peak to peak signal with it is 16mV
Did you measured free-standing 1k resistor (not connected to this PSU)?
This is far more than predicted 80uV Johnson noise few posts above. Perhaps an osciloscope issue?
LM317/337 ripple/noise/oscillationHide this!Advertise here!
Reduce SMPS ripple noise for PreAmp? forestsgump Power Supplies 42 15th February 2018 04:01 AM
Check my figures for LM317 ripple dotneck335 Power Supplies 26 15th November 2017 11:10 AM
AMC 3030 annoying ripple noise SimpleMind Tubes / Valves 8 18th March 2017 07:53 PM
Low Noise/Ripple 24Vdc 12 Psu (100mA) mrr76 Power Supplies 4 23rd July 2013 04:17 AM
Borbely PS has 5 uV noise and ripple - little or much? Sigurd Ruschkow Power Supplies 16 2nd April 2005 11:38 AM
