What are the considerations regarding the transformer output voltage when using a regulated output with a push pull design. How much higher should the open loop output voltage vs. the closed loop voltage. Obviously if the output voltage is below the set point with the regulator (TL494) at 100% duty cycle the set point can not be reached. What is a reasonable duty cycle at full load and low input voltage.
The last few pages of some of the datasheets from Linear Technology have the equations -- its a function of duty cycle, minimum and max current etc. Look at the last few pages of the lt3439 low noise push-pull converter: http://cds.linear.com/docs/en/datasheet/3439fs.pdf
i put it into excel-- but it's not on this computer.
jack
jack
- Power Supplies
- SMPS Tranformer design
