Using power extension with surge protection for a krell
Old 1st January 2018, 10:26 AM   #1
02GF74 is offline 02GF74  United Kingdom
Default Using power extension with surge protection for a krell
Happy New year to all.
In an ideal world I would have dedicated mains sockets for my hifi but I don't.
I'm using two 6 way extensions each (ml speakers, cyrus
Cd/pre - each with psxr and krell ksa 150).
I'm looking at a single 8 way extension which comes in 2 flavours, with and without surge protection.
Will the surge protection interfere with the operation of the krell? I know krells draw a lot of current at power up and I understand that they have current limiting circuitry so don't see it as an issue.
Interested to hear your experiences.
Old 1st January 2018, 10:32 AM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
It will make no difference. The surge protection is against voltage surges in the mains, not current surges during equipment turn on.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 1st January 2018, 10:59 AM   #3
basreflex is offline basreflex  Spain
adding many surge protections to your local mains circuitry could result in preliminary tripping of your GFI. small voltage spikes are shorted to ground, unbalancing the load and triggering the GFI. you then have to buy an expensive noise immune GFI.
another solution is to add a true overvoltage protector where the mains enters the house, (in some countries this is a standard requirement)
Old 1st January 2018, 11:03 AM   #4
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
GFI?= "Earth Leakage Relay"?
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 1st January 2018, 11:07 AM   #5
Ground Fault Interruptor = earth leakage relay
Old 1st January 2018, 11:10 AM   #6
Interruptor, that was the word I couldn't guess Thanks.
Only, thinking about it, it's not really a ground fault that's being interrupted, nevermind, ignore me!
Old 1st January 2018, 10:35 PM   #7
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by scottjoplin View Post
....it's not really a ground fault that's being interrupted, nevermind, ignore me!
Off-topic taken here: GFI, RCB, and dirt
Old 2nd January 2018, 05:29 PM   #8
R.I.P.
The usual recommendation is that the earth leakage current should be less than 25% of the rated trigger level of the RCCB (Residual Current Circuit Breaker). The older term in the UK was RCD
In the UK it is usual for non critical household use that a 30mA RCCB be used.
That then would limit the normal leakage current to <7.5mAac
If the total household leakage is higher than that, then one has the option to provide RCCBs to individual power circuits (fairly easy to do at the house distribution board), or to remove high leakage equipment from the RCCB protected circuits and run separate power to these high leakage circuits (potentially very expensive to install). Older PC monitors of the CRT style often had high leakage that took many RCCBs too close to their trigger level in normal operation.
The RCCBs seeing a normal leakage of <25%, has an allowance to interference and other non dangerous leakage of ~22.5mAac
This is a big allowance for all properly operating and properly maintained domestic equipment.
If one is having repeated tripping of an RCCB, then it's time to call in a qualified Electrician who has the required test equipment to determine which equipment is the cause of the problem and to give advice on the long term solutions.
The wiki RCD description has many mistakes in the introductory paragraph and needs an informed Electrical Engineer to edit it.
Residual-current device - Wikipedia
regards Andrew T.
Using power extension with surge protection for a krellHide this!Advertise here!
Mobile festival PA voltage, surge, brownout protection & do no evil to others Phenoholic Anonymus PA Systems 15 16th October 2015 12:32 PM
Surge protection - extension lead or MOV? Kev06 Power Supplies 23 6th February 2014 12:09 PM
Surge Protection Component - Help Fidelity Audio Everything Else 5 30th May 2012 04:36 AM
Surge Protection Component - Help Fidelity Audio Parts 39 31st March 2012 07:15 AM
My first simple mains conditioner/surge protection: maxlorenz Parts 29 7th January 2006 05:53 PM
