Help for PMillett HV regulator
Old 1st January 2018, 10:21 PM   #11
6L6 is offline 6L6  United States
6L6's Avatar
Do you have RV1 removed and open or jumpered? It needs to have a jumper so R4 can connect to ground.
Old 2nd January 2018, 04:45 AM   #12
crazyfrog is offline crazyfrog  Canada
RV1 (2K) is well installed but set at "zero" just to make the test simpler. In that case the reading between LM317 adj pin and ground is 10K (R4 value).
Old 2nd January 2018, 04:53 AM   #13
Originally Posted by PRR View Post
Thanks again. But there is still a GD thing I don't see on that board...
Old 2nd January 2018, 09:50 AM   #14
FLT is offline FLT
Default stupid question...
you have 140V Input and 130V Output= 10V Difference.
D1 is a 15V Zener and R1 has 100kOhm.
For a Zener current of 1mA R1 has 100V drop.
I don't know how this can work and didn't find an Input voltage range
on pmillet's site.
regards
frank
Old 2nd January 2018, 01:50 PM   #15
6L6's Avatar
I'm wondering about dropout as well. But remember he wants 105V output.
Crazyfrog - solder a 7-8k resistor (or so) across R5 and then see if you can get any adjustment in output voltage with the pot.
The other trick to try is to make R5 100ohm or so, which will pull more current through the 317
Old 2nd January 2018, 05:17 PM   #16
Default Found it!
Re-checked all ( possible) parts with DMM: GOOD
Re-checked for discontinuity from part to part: GOOD
However, since 10.6V on D1 was "weak" (see post 9), I took readings of voltage backwards from there until the adjust pin: BAD from D1 to R3. The bobo was 1N4148. And it was testing good... Never occured to me to check there. Anyway I just put a new one and it's working fine. Thanks to all for your help and interest (especially to PRR for the "educational" diagram ).
Pierre
Old 2nd January 2018, 05:48 PM   #17
R.I.P.
Are D1 & D2 referenced to the output voltage?
What happens at start up when the output voltage is at zero volts?
regards Andrew T.
Old 2nd January 2018, 06:32 PM   #18
PRR is offline PRR  United States
PRR's Avatar
Originally Posted by AndrewT View Post
...What happens at start up when the output voltage is at zero volts?
Output at zero. D1 holds Q1 Gate at +15V. Q1 Source rises near +18V. The LM317 is entirely safe for voltage; Q1 must stand about 120V but is a 700V part (tho shunted with a 530V TVS). LM317 can still shut-down on over-current, any large output cap will charge at ~~1A. Less if it goes on long enough to make the '317 hot.
The whole D1-Q1-LM317 rig rises as output voltage rises. '317 should never have over about 18V across In/Out. If we screw-up, D5 should limit to 39V across the '317.
There are more stumbles possible when power turns off. That is why you need D5 D3- so any output cap is discharged around the '317 (which dislikes reverse current). Also D2 takes-down bypass C2.
If D2 is shorted, output setpoint is 210V. With only 140V coming in, it may go to 130V. If D2 is installed (or marked!) backward, output setpoint is 155V-160V, so again we may get 130V.
Old 3rd January 2018, 07:57 AM   #19
R.I.P.
Thank you for talking/taking me through that.
regards Andrew T.
Help for PMillett HV regulatorHide this!Advertise here!
PMillett Landfall heatsink wicked1 Tubes / Valves 29 11th August 2014 08:51 PM
pmillett Tube Active Crossover whitelabrat Group Buys 8 24th February 2010 07:47 PM
