Grounding with separate enclosures?
Old 5th February 2018, 03:25 PM   #41
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
Good point
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 5th February 2018, 03:29 PM   #42
forr is offline forr  France
forr's Avatar
Originally Posted by scottjoplin View Post
Ok, you don't want to connect 0V to chassis because PE may be noisy, fair enough. On a side note, oscilloscope 0 volts/reference is usually connected to PE, why is that done?
Safety.
But there exist safe scopes with floating inputs which just allow to avoid the connection to earth.
EDIT
Have you noticed that scopes do not have a star ground scheme ? Why is that done ?
Grounding with separate enclosures?Hide this!Advertise here!
Hypex UcD and SMPS in separate enclosures? ChrisPa Class D 0 18th February 2010 10:29 AM
Simple grounding question (separate power supply) sneakers563 Power Supplies 3 23rd January 2010 03:57 PM
Grounding with separate enclosures CfM Power Supplies 4 28th March 2009 03:12 AM
Separate PSU grounding decky Power Supplies 1 20th March 2008 08:40 PM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
