Looking for some power intelligence.
PRR
Joined 2003
But would that not produce unbalanced voltages in the secondary winding due to unsymmetrical currents flowing in the common third connection because of unbalanced loads?
It can be 275 -or- 330V.
It wants a full-wave bridge, as said.
If you just use the 275V winding, you "waste" about 10% of the copper+iron you paid for. This "waste" is small compared to the benefit of getting closer to your intended DC voltage, which is always partial guess-work due to bad sag in capacitor-input filters and incomplete specification of all parasitics.
Expect either 380VDC or 460VDC. Or less if your load is close to 400mA AC (with cap-input, about 250mA DC).
This PT can power around 50W-60W of tube-amp. 6L6 or EL34 at 4K load, for example.
