Is there anything wrong with this PS design?
Old 24th December 2017, 01:19 PM   #1
simonra is offline simonra  United Kingdom
Default Is there anything wrong with this PS design?
Hi, I built a few of these power supplies a while ago. Looking now at the schematic I cannot remember why I chose to use an LM317 on both rails instead of going for an LM337 on the negative supply.
Is there a reason why this shouldn't work? - I've used this supply on a preamp that I'm fault finding and I just wanted to see whether I would be better off regulating the negative rail to eliminate potential problems with the PS.
Thanks,
Simon.
Old 24th December 2017, 01:54 PM   #2
MorbidFractal is offline MorbidFractal
Conceptually and operationally I would say no.
You might have been forced to use an LM317/LM337 if your transformer had a fixed centre tapped secondary but since you have access to both secondaries separately I see no problems with your chosen solution.
Maybe you forgot that you had an AHA! moment.
Of course it may be the case that, in audio terms, people will start to have kittens about ground... or something else. Me, not so much but perhaps you might revisit your PCB and check it. I cannot see the bottom layer and your top section appears to have a split plane?
Old 24th December 2017, 01:59 PM   #3
rayma is offline rayma  United States
for an LM337 on the negative supply. Is there a reason why this shouldn't work?
This is fine, and the 317 is better than the 337.
Old 24th December 2017, 02:33 PM   #4
Thanks guys, nice to have some confirmation. The split on the top plane is between unregulated and regulated positive supply.
Old 24th December 2017, 03:05 PM   #5
Shows how bad my old eyes, reverse engineering skills, are.
Unrelated but just to be a pedant... Your primary side may violate regulatory requirements in respect of creepage/clearance Live to Neutral.
Something like this one here,
https://www.electricalsafetyfirst.or...4/Chargers.pdf
Page 3) Other,
Other:
The measured creepage distance between Live and Neutral before any fusing was 2.1mm and the measured clearance distance was 1.8mm, the minimum requirement is 2.4mm.
Old 24th December 2017, 03:53 PM   #6
Yes, looks as though the clearance between the live pins of the molex connector and the neutral pour are well below that tolerance. I have a vague memory of checking the clearance limits but probably not against regulatory requirements... thanks for the link, I'll do a bit of Christmas reading .
Old 24th December 2017, 04:46 PM   #7
Whatever 'floats your boat'. In fact it looks like it is worth a read.
I was just looking for an example. Last time I did this stuff I ended up joining BSI so I could get the standards half price rather than relying on someone else's 'word of mouth'.
It looks like
Electrical Safety First - The UK's Electrical Safety Experts
might have submitted a bunch of chargers to BSI in Hemel Hempstead for appraisal. The pictures suggest that they are 'Pre-Loved'.
Otherwise, somehow, they still got sold in the UK.
It is one of the things that puts me off buying nondescript 'drop shop' stuff from Ebay, especially when it is mains operated. If it does not blow itself up it is likely to be a safety hazard.
Old 25th December 2017, 09:49 AM   #8
R.I.P.
your layout will not perform at the best that a 317 can achieve.
If I am reading your layout correctly then it appears that the top left pin of the VR is connected to the blue plane and the -ve end of C5 is also connected to the blue plane.
But these two connections are far apart.
The output Zero Volts is also on the blue plane.
These three tappings into the blue plane are supposed to all be at the same voltage.
But you have them spread about at distances that can't get much bigger.
The closer you can make these three tappings the better the regulation.
Aim to get VR pin1 + C5-ve +Zero Volts out, to be near coincident or within a couple of mm of each other.
Similarly the output resistance/impedance is affected by the length of the trace from reg OUT to Zero Volts out. Minimise this distance.
The negative has to follow the same laying out philosophy.
The VR -ve end +C8 -ve end and -ve out all need to be very close to each other.
and reg out needs to be very close to zero volts out.
regards Andrew T.
Old 25th December 2017, 10:44 AM   #9
Keruskerfuerst is offline Keruskerfuerst  Germany
Keruskerfuerst's Avatar
For what purpose is the PSU?
Old 25th December 2017, 10:54 PM   #10
The component U$1 is a pot (i forgot to set the right identifier in Eagle), IC1 is the regulator. Regulator input is the left red plane and output is to the right red plane.
Looking at the layout again in the light of your comments I can see that it could have been much tighter... I'll work further on the schematic before I get any more of these boards made up.
Thanks for the advice.
Is there anything wrong with this PS design?Hide this!Advertise here!
What am I about to do wrong? (beginner attempting 3 way L/R mains design) DampedAndDriven Multi-Way 4 19th July 2017 12:51 AM
Is there any thing wrong with this design tony Ma Power Supplies 22 31st March 2013 05:44 PM
Is % open area the wrong parameter for ESL stator design? Few Planars & Exotics 6 23rd May 2007 09:58 PM
Anything wrong with my first sub design? angsuman Subwoofers 9 23rd November 2005 01:38 AM
Anything wrong with this design? FrancoB Tubes / Valves 4 27th April 2005 06:50 AM
