Op amp Linear power supply
Old 18th December 2017, 11:32 PM   #1
Marksd is offline Marksd  United States
Default Op amp Linear power supply
I have a question concerning the following. I am only a small time self taught hobbiest. I have a 741 op amp driving a TIP 102 NPN Darlington current pass transistor. I have two loads attached. One load draws .240 amps. The second load draws 1.150 amps. I can set the voltage output for the first load at 11.8 volts. When i switch the to the 1.150 amp load the voltage drops by almost .3 to .5 volts. My supply is 15 VDC. I use a 50 ohm resistor for the .240 Amp load and a 10 ohm resistor of for the 1.150 amp load. The transistors are heatsink mounted when testing. The heatsink temperature rises from about 23C to 77C with the higher amperage load. I also tried a PNP TIP 147 darlington and while it functions better suffers from the same larger than expected voltage drop changing from one load to the another. I have 2.4 to 3.2 volts on each darlington from collector to emitter so i think these are in saturation. I used the darligntons due to the op amp output current. The spec sheet says i only need about 300 microamps to get then current output. So, I tested a IRF9540 P channel mosfet with the same two loads and it holds within .04 volts regardless of load. Regulation from cold to hot is almost 99% accurate. Same temperature rise on the heatsink with the mosfet. I think I am operating the mosfet in saturation, but just barely.
Please help with any explanation as to why the darlington are losing, (not regulating) the voltage between current loads and any improvements I can make to allow the use of the darligntons. Regulation changes with an increase in temperature. How can I fix this too. I don't care whether I use NPN or PNP because they are inexpensive. Thanks.
Old 18th December 2017, 11:45 PM   #2
rayma is offline rayma  United States
Can you post a schematic?
Old 21st December 2017, 03:45 AM   #3
dotneck335 is offline dotneck335  United States
I still challenge anyone to beat this supply for $10!!
LM317 / LM337 +/-1.5V~37V Adjustable Dual Voltage Regulator Power Board | eBay
Old 21st December 2017, 09:37 AM   #4
r_merola is online now r_merola  Brazil
Do you have schematics of this power supply?
It is attractive for lower cost and good presentation, but what is the function of the DIP8 operational amplifier as it have 2 voltage adjusts for positive and negative rail voltage. (supposed some kind of noise filter)
One problem of this kind of symmetrical regulator is the lack of protection systems to turn off both regulators when one fails.
Ronaldo
Old 21st December 2017, 10:34 AM   #5
infinia is offline infinia  United States
infinia's Avatar
Historically PNPs were double the cost at lesser specs than NPNs.
You are probably running out of "headroom" E.g. the voltage difference required between regulators pass input and the output and still remain in "regulation" under all operating conditions.( low line voltage, etc )
1) The regulators Vinput drops under load.
Consider the raw DC voltage will drop under load and it has AC ripple on it/. you can measure or estimate both. You must subtract from the average DC the lowest ripple valley. E.g. negative peak AC ripple component under full load is technically the correct Vin. Its normal to have 1 Vrms ripple at full load which is about 2.8 V peak-peak, so it's very possible for this to be worse if the bulk filter caps are wimpy.
2) The regulator needs the V error op-amp's output level and current to support the transistors Vbe's and any beta droop.
Look at the devices data sheets to calculate the level drop starting at the Op-amps Vout thru two Vbe's of the darlington. Next look at the op-amp current needed to support the full load. One trick is to tie the op-amps supply a few volts higher than the raw DC. The op-amps output current could still be too weak. But it's better to test it and see what headroom you have 1st. I'd suggest drop the output voltage by 2 or 3 volts and recheck.
Things to consider , either all or in combination of.
a) Use a beefier' Xfmr and filter capacitor.
b) Use a better op-amp and /or run it from a higher voltage.
c) Check the pass and driver transistors betas. Change the whole topology for "low drop out" performance. one thing you said a MOSFET pass element works with your op-amp and reference, right?
d) Reduce your specs E.g Output current and voltage to account for poor headroom. (this is the easiest solution)
Old 21st December 2017, 05:00 PM   #6
Jenyok is offline Jenyok  Russian Federation
LM317 load capacitance
See those circuits. They specially disigned for low noise application. MIC preamp, RIAA, playback amp, DAC converters.
Old 21st December 2017, 08:17 PM   #7
MorbidFractal is offline MorbidFractal
You make a reference to the spec sheet for the Darlingtons. Did you consider the spec sheet for the operational amplifier?
http://www.ti.com/lit/ds/symlink/lm741.pdf
Check the output voltage specifications. Page 5) 6.5] Minimum output swing is +/-12V.
As infinia mentions your NPN will drop an extra 1.2V so it will likely be slightly rubbish. Your PNP may be better because you gain an extra 1.2V, pull down to turn it on. The P-Channel mosfet will be happiest of the three because the gate will need to be about 3V/5V below source for it to start conducting. It will also need less drive.
You also need to check Fb/Ft for your chosen transistors.
Also the 741 only has a Gain Bandwidth Product of 1MHz
The following is an 'idealised' LTSpice model which may give you some ideas about how to do it. Also includes a 'concept' of foldback current limiting. It also lets you check the Loop Gain. Plot V(A)/V(B).
Loop stability is important.
Code:
Version 4
SHEET 1 1224 832
WIRE 288 -240 -576 -240
WIRE 384 -240 288 -240
WIRE 480 -240 384 -240
WIRE 752 -240 480 -240
WIRE 288 -208 288 -240
WIRE 480 -208 480 -240
WIRE 752 -208 752 -240
WIRE 384 -96 384 -240
WIRE 480 -48 480 -128
WIRE 480 -48 448 -48
WIRE 528 -48 480 -48
WIRE 640 -48 608 -48
WIRE 752 -48 752 -128
WIRE 752 -48 640 -48
WIRE 640 -16 640 -48
WIRE 288 32 288 -128
WIRE 384 32 384 0
WIRE 384 32 288 32
WIRE 480 48 480 -48
WIRE 752 48 752 -48
WIRE 640 96 640 64
WIRE 688 96 640 96
WIRE 640 128 640 96
WIRE 288 176 288 32
WIRE 576 176 288 176
WIRE -304 256 -448 256
WIRE 480 256 480 128
WIRE 480 256 -224 256
WIRE 624 256 480 256
WIRE 640 256 640 224
WIRE 640 256 624 256
WIRE 752 256 752 144
WIRE 752 256 640 256
WIRE 784 256 752 256
WIRE 288 304 288 176
WIRE -448 352 -448 256
WIRE -304 352 -448 352
WIRE -96 352 -240 352
WIRE 80 352 -96 352
WIRE 224 352 192 352
WIRE 80 384 48 384
WIRE -448 432 -448 352
WIRE -368 432 -448 432
WIRE -240 432 -304 432
WIRE -96 432 -96 352
WIRE -96 432 -176 432
WIRE 288 448 288 400
WIRE 400 448 288 448
WIRE 400 480 400 448
WIRE 624 480 624 256
WIRE -448 496 -448 432
WIRE -304 496 -448 496
WIRE -96 512 -96 432
WIRE -96 512 -240 512
WIRE -64 512 -96 512
WIRE 48 512 48 384
WIRE 48 512 16 512
WIRE 80 512 48 512
WIRE 192 512 192 352
WIRE 192 512 160 512
WIRE -304 528 -336 528
WIRE -576 592 -576 -240
WIRE -448 592 -448 496
WIRE -336 592 -336 528
WIRE 288 592 288 448
WIRE 400 592 400 544
WIRE 624 592 624 544
WIRE 752 592 752 256
WIRE -576 704 -576 672
WIRE -448 704 -448 672
WIRE -448 704 -576 704
WIRE -336 704 -336 672
WIRE -336 704 -448 704
WIRE 288 704 288 672
WIRE 288 704 -336 704
WIRE 400 704 400 672
WIRE 400 704 288 704
WIRE 624 704 624 672
WIRE 624 704 400 704
WIRE 752 704 752 672
WIRE 752 704 624 704
WIRE -576 736 -576 704
FLAG -576 736 0
FLAG 784 256 VOUT
IOPIN 784 256 Out
FLAG 80 352 A
IOPIN 80 352 Out
FLAG 80 384 B
IOPIN 80 384 Out
SYMBOL pnp 688 144 M180
WINDOW 0 74 61 Left 2
WINDOW 3 75 37 Left 2
SYMATTR InstName Q1
SYMBOL pnp 576 224 M180
WINDOW 0 60 57 Left 2
WINDOW 3 62 32 Left 2
SYMATTR InstName Q2
SYMBOL res 624 -32 R0
WINDOW 0 39 43 Left 2
WINDOW 3 48 70 Left 2
SYMATTR InstName RDAR
SYMATTR Value 4K7
SYMBOL res 736 -224 R0
WINDOW 0 37 52 Left 2
SYMATTR InstName R10
SYMATTR Value 500m
SYMBOL res 272 -224 R0
WINDOW 0 39 55 Left 2
SYMATTR InstName R6
SYMATTR Value 10K
SYMBOL npn 224 304 R0
WINDOW 3 57 58 Left 2
SYMATTR InstName Q3
SYMBOL res 272 576 R0
WINDOW 0 38 55 Left 2
WINDOW 3 39 76 Left 2
SYMATTR InstName R4
SYMATTR Value 10K
SYMBOL res 176 496 R90
WINDOW 0 0 56 VBottom 2
WINDOW 3 32 56 VTop 2
SYMATTR InstName R3
SYMATTR Value 1K
SYMBOL cap 608 480 R0
WINDOW 0 44 19 Left 2
WINDOW 3 45 40 Left 2
SYMATTR InstName C3
SYMATTR Value 220
SYMBOL voltage -336 576 R0
WINDOW 0 41 44 Left 2
WINDOW 3 39 68 Left 2
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName VREF
SYMATTR Value 2.5V
SYMBOL res -208 240 R90
SYMATTR InstName R2
SYMATTR Value 8K2
SYMBOL cap -240 336 R90
WINDOW 0 0 32 VBottom 2
WINDOW 3 32 32 VTop 2
SYMATTR InstName C1
SYMATTR Value 39p
SYMBOL res -464 576 R0
WINDOW 0 36 47 Left 2
WINDOW 3 35 69 Left 2
SYMATTR InstName R1
SYMATTR Value 2K2
SYMBOL voltage -576 576 R0
WINDOW 0 44 48 Left 2
WINDOW 3 43 71 Left 2
SYMATTR InstName VCC
SYMATTR Value 15V
SYMBOL res 736 576 R0
WINDOW 0 34 49 Left 2
WINDOW 3 32 75 Left 2
SYMATTR InstName RLOAD
SYMATTR Value 10R
SYMBOL voltage 32 512 R90
WINDOW 0 -32 56 VBottom 2
WINDOW 123 60 59 VBottom 2
SYMATTR InstName V1
SYMATTR Value ""
SYMATTR Value2 AC 1
SYMBOL res 608 576 R0
WINDOW 0 38 53 Left 2
WINDOW 3 42 76 Left 2
SYMATTR InstName RESR
SYMATTR Value 50m
SYMBOL res 624 -64 R90
SYMATTR InstName R9
SYMATTR Value 1K
SYMBOL res 464 -224 R0
WINDOW 0 36 53 Left 2
SYMATTR InstName R7
SYMATTR Value 1K
SYMBOL pnp 448 0 R180
WINDOW 0 100 62 Left 2
WINDOW 3 76 33 Left 2
SYMATTR InstName Q4
SYMBOL Opamps\\opamp -272 448 R0
SYMATTR InstName U1
SYMATTR SpiceLine2 GBW=1Meg
SYMBOL diode -176 416 R90
SYMATTR InstName D1
SYMATTR Value ZID
SYMBOL diode -368 416 M90
SYMATTR InstName D2
SYMATTR Value ZID
SYMBOL cap 384 480 R0
WINDOW 0 43 23 Left 2
WINDOW 3 43 49 Left 2
SYMATTR InstName C2
SYMATTR Value 100n
SYMBOL res 384 576 R0
WINDOW 0 39 53 Left 2
SYMATTR InstName R5
SYMATTR Value 470R
SYMBOL res 464 32 R0
WINDOW 0 38 42 Left 2
WINDOW 3 40 66 Left 2
SYMATTR InstName R8
SYMATTR Value 10K
TEXT -536 792 Left 2 !.LIB OPAMP.SUB
TEXT -536 816 Left 2 !.ac dec 50 100 1E6
TEXT -536 768 Left 2 !.MODEL ZID D(Ron=10m Roff=1E9 Vrev=5V)
Old 23rd December 2017, 12:43 PM   #8
....... but what is the function of the DIP8 operational amplifier as it have 2 voltage adjusts for positive and negative rail voltage. (supposed some kind of noise filter)
LF353 provides feedback to lower noise.
File Type: doc LowVoltageRegulatorWithOpampFeedback.doc (87.0 KB, 86 views)
Old 23rd December 2017, 02:04 PM   #9
Mooly's Avatar
This is the most important point. We need to see the circuit to advise.
The most important points are that the output voltage itself is monitored and included within the feedback loop to the opamp. Secondly, if using an NPN pass transistor then you must ensure that there is sufficient headroom available for the opamp which simply means 'is the supply voltage high enough'.
If those points are covered then the circuit should show no appreciable change in output voltage with varying load.
Here are the two scenarios. See how the opamp output voltage is quite high in the second example as it looks to drive the darlington pair.
Old 23rd December 2017, 05:20 PM   #10
infinia's Avatar
The most important thing is the measured voltages DC + AC under load.
The schematic alone wont tell us were the problem is. From the OP symptoms points to what the fundamental problem is, loses regulation under load. The best advise was to lower the output voltage until it regains regulation, If it doesn't happen then the circuit is broken. Infact he could use a potentiometer to determine the required headroom for any reasonable Vreg schematic. I agree schematics are helpful but necessarily mandatory given the OP's level and experience.
Op amp Linear power supplyHide this!Advertise here!
Linear power supply Jolida Power Supplies 7 13th October 2016 07:10 AM
Linear Power Supply - How-To Astera Class D 6 5th February 2013 09:04 PM
Linear power supply movie_fan PC Based 0 27th September 2011 12:47 AM
Power One 5v 3A linear power supply SilverStrings Swap Meet 0 23rd September 2010 06:06 AM
Power One 12V 10A linear power supply boywonder Swap Meet 0 11th September 2010 03:38 PM
