LM317 HV PSU
LM317 HV PSU
Old 5th December 2017, 09:03 PM   #11
Elvee is offline Elvee  Belgium
Elvee's Avatar
I your mind is not definitely set on using a 317, here is a discrete alternative.
It might be a bit more complex, but certainly not more expensive and offers similar performances.
The main advantage is a vastly improved ruggedness in real life situations, but it is also more frugal, wastes less dropout voltage and offers a higher level of flexibility.
Simple HV series regulators
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 5th December 2017, 10:58 PM   #12
mchambin is offline mchambin  France
Originally Posted by scottjoplin View Post
You are right but the problem is that at power up the output capacitor appears as a near short to 0V
Si ą zener is a must across Vin and Vout.
Transistor junction temperature is not transistor case temperature.
Old 6th December 2017, 02:20 AM   #13
dotneck335 is offline dotneck335  United States
Yeah, I've always thought that adding a 40 volt Zener across the in & out terminals of the 317/337 would be a good idea. I've not blown up a 317 without it, but it sure has happened to me with LT1083s.
Old 6th December 2017, 03:25 AM   #14
Originally Posted by Kay Pirinha View Post
High current - yes, with the drawbacks that the power devices' emitter balancing resistors are missing and that there's no overload protection at all.
Well, the emitter resistors aren't really needed if you beta-match the pass- transistors.
LM317 HV PSUHide this!Advertise here!
The best LM317 .... NRWler04 Solid State 2 18th February 2013 03:32 PM
±45v lm317? linxiaoxin Power Supplies 10 23rd April 2012 11:14 AM
LM317 cleanup vaioble Power Supplies 25 31st March 2012 02:05 PM
LM317 happy hippy Power Supplies 63 20th January 2012 06:31 PM
Lm317 jlm Power Supplies 9 2nd February 2006 08:31 PM
