Battery DC converter
Old 28th November 2017, 05:58 PM   #21
mchambin is offline mchambin  France
Originally Posted by miro1360 View Post
first try more diodes in parallel, if datasheet is right, than low current leads to lower temperature and lower voltage drop ... more diodes parallel == less current through one diode
Not a chance it would significantly lower the voltage drop.
Firstly, they will not share current equally.
Secondly, assuming equal share, the drop will be very little because of the V versus I of diodes.
Transistor junction temperature is not transistor case temperature.
Old 28th November 2017, 06:39 PM   #22
miro1360 is offline miro1360  Europe
I am also not sure, in simulation diode which I suggested have this behavior:
https://ctrlv.cz/shots/2017/11/28/suw8.png (load 430mA)
as you can see, more parallel theoreticaly leads to decreasing current through one diode and voltage drop is less in result, but yes, reality can be different ... still not 0.2V but is closer
Old 28th November 2017, 06:57 PM   #23
Of course it theoretically decreases the voltage drop.
The point is: You can parall tons of diodes the decrease will not be significant.
See it this way: Ten diodes in // is the same as a single diode that has a junction 10 times larger.
Old 28th November 2017, 07:44 PM   #24
or even better this one:
VS-STPS20L15D-N3 Vishay
https://ctrlv.cz/shots/2017/11/28/tFqx.png
or this
yes, try some for higher current, more parallel decrease also temperature and voltage should be better ...
Old 28th November 2017, 08:13 PM   #25
Fob69 is offline Fob69  France
This one : VS-10BQ015HM3-5BT was given to be -0,21V at 1A and i have -0,3V at 450 ma ... I will try tomorrow with 3 or 4 in parrallel
B.
Old 28th November 2017, 08:26 PM   #26
Ok, now I see.
From the datasheet:
At 1A 125C ....Vf is 0.21V
At 1 25C....Vf is 0.33V
So this 0.2V is misleading.
You have 0.33V, if this is true, it is a good performance for a Shotsky diode.
Look at power Germanium diodes. You should find true below 0.3V.
Old 28th November 2017, 08:34 PM   #27
Yes i have.
Gonna buy a used grill on ebay
Old 29th November 2017, 06:23 AM   #28
For some odd raison I missed why you need diodes.
There might be a solution using ultra caps.
They are capacitors with so huge capacities, they can be used as batteries.
They have less capacity than batteries, but can be quick charged much faster.
Old 29th November 2017, 06:32 AM   #29
I need diods to adjut lifepo4 output batteries voltage without to loose the vey low impedance.
I use batteries because i want ultra low noise supply and AC isolation for devices upstream my DAC (downsream Delock MFC and Olimex lime player). Lifepo4 batteries is IME from far the best result in SQ.
Old 29th November 2017, 07:32 AM   #30
You can use LM337 for a ultra low noise supply.
There is no need for huge caps or sophisticated add ons.
Cascading two LM337 will give zero ripple.
Battery DC converterHide this!Advertise here!
LiFePO4 battery psu for PUC2 Lite USB-AES converter Oceanw Power Supplies 9 16th October 2015 08:19 AM
can I use converter to 24v from 12v battery hormilo Power Supplies 8 5th June 2014 09:47 AM
12vDC to 110vAC converter with 18v battery DarpMalone Power Supplies 0 20th July 2013 12:11 AM
250 W boost converter for 12 V car battery Bootstrapper Power Supplies 29 22nd September 2008 10:52 AM
Battery Based High-End DA Converter. yangsmm Vendor's Bazaar 14 21st August 2008 12:24 PM
