Check my figures for LM317 ripple
is the 317 noise relative to the 1.25 volts at the reference pin?
If one is using the 317 to give a regulated output of 5Vdc, then the voltage divider feeding back into the ref would be quadupling the ref voltage. Does that double or quadruple the noise on the output line?
What if one were outputting a regulated 25Vdc?
Does the noise get multiplied up for that?
