Super caps Ultra caps
Old 9th November 2017, 09:38 AM   #21
mchambin is offline mchambin  France
Air core transformers, or inductors are usual at RF frequencies.
I have not seen it at lower frequencies.
Transistor junction temperature is not transistor case temperature.
Old 9th November 2017, 10:32 AM   #22
DF96 is online now DF96  England
Surely an air-core transformer would be better at passing on HF noise - so worse isolation?
Old 9th November 2017, 12:35 PM   #23
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by analog_sa View Post
How would the absence of a core help?
The usual kind of mains transformer has a laminated steel core. Steel is a conductor, hence there's stray capacitance between primary and secondary via the core. With an air cored transformer, this path is absent so there is only the direct capacitance between the windings. When I made some rudimentary measurements on a split bobbin transformer, the removal of the core reduced the interwinding capacitance by around two thirds (from memory).
I know you think you understand what you thought I said but I'm not sure you realize that what you heard is not what I meant - Alan Greenspan
Old 9th November 2017, 12:48 PM   #24
Indeed.
However, there is no way to make a mains 50 or 60Hz transformer without an iron core.
Not that is impossible...., The size of an air core mains tranformer would be humongous. Anyone to calculate such a transformer ?
Old 9th November 2017, 12:54 PM   #25
abraxalito's Avatar
There is - use ferrite. But that's jolly inefficient because your maximum flux is extremely limited. So its only good if your power requirements are really modest. Power amps are out. The number of turns on the primary is scary large, not one I'd want to wind myself.
Old 9th November 2017, 01:03 PM   #26
Ferrite was used in radio receivers at 445 KHz for the intermediate frequency amplification.
Typically ( 120db gain ) two tuned circuit stages implemented with ferrite core transformers, the cores where used for fine tuning.
I think, this became obsolete with PLL ( Phase Lock Loop ) techniques.
AM intermediat frequency is 445 KHz.
FM intermediat frequency is 10.7 MHz.
I have seen ferrite used at lower frequencies to implement high Q filters in the audio band with ferrite pots.
I have seen ferrite pots for DC to DC converters. That is close to power supply. But frequencies far higher than 50 Hz.
Old 9th November 2017, 01:18 PM   #27
abraxalito's Avatar
Sure, no-one wants to use ferrites at 50 or 60Hz unless there are compelling reasons. And in general there aren't, for power applications. Signal transformers though are another matter - I've been winding ferrite cored signal transformers for a number of years. They're easy to diy and much cheaper than nickel/steel cored ones. Of course the flux limitation is still the major issue but with signal trafos we care much less about copper losses so using more turns of thinner wire isn't normally a big problem.
NiZn ferrites might be an alternative to air-cored transformers as NiZn material has high resistivity. I've not played with any cores made from this though so I'm just speculating. Of course to transfer any power it would need to operate well above mains frequency.
Old 9th November 2017, 01:35 PM   #28
Interwinding capacitance can be reduced by using an interwinding screen. The core can be grounded. More to the point, a typical power transformer iron core is poor at magnetic coupling at high frequencies due to eddy current losses. Air core (or ferrite) would not suffer so more interference could get in, not less. People already complain that toroidal transformers let though more rubbish than old-fashioned EI etc.
Old 9th November 2017, 01:37 PM   #29
I did not master ferrite technology. There are many materials to choose from for different applications, frequencies.
Old 9th November 2017, 01:38 PM   #30
abraxalito's Avatar
Poor magnetic coupling doesn't affect the rejection of common-mode noise, only normal mode.
Super caps Ultra capsHide this!Advertise here!
Ultra caps jwyoungster Everything Else 8 20th January 2014 10:08 PM
Super caps... Boscoe Power Supplies 5 31st March 2013 12:34 AM
FS: Capacitor Lots: Oil caps, HV Film Caps, Polystyrene Caps mattattnet Swap Meet 1 8th December 2012 08:20 PM
FS: VTV Ultra-Tone .047uF 600V PIO caps beeah Swap Meet 6 26th April 2010 06:10 PM
Black Gate 'super E' caps Terry Demol Parts 99 7th September 2005 01:26 AM
