I keep checking my references, it seems that the Cs location on the board is where you put the 0.15uF cap, and the Cx is where the 0.01uF cap goes. I just can't bring myself to solder them in place because one location has provisions for 2.5-5.0mm lead spacing, the other has 5.0-7.5mm, and the larger location is where the small cap goes, and the small location is where the large cap goes!
Is this correct? Why was the board designed this way when it's obviously backwards? Or am I having a brain fart?
