LM317 load capacitance
Old 4th December 2017, 01:54 PM   #341
gerhard is offline gerhard  Germany
gerhard's Avatar
Originally Posted by mchambin View Post
What about the pictures transmitted from Pluto ?
Phone home.
You have a message from Andromeda.
That is easy nowadays. Just install some Apple,
Google or Amazon software on the deep space probe
and that phone home thing will work.
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
Old 4th December 2017, 06:47 PM   #342
infinia is offline infinia  United States
infinia's Avatar
spoken like a true hardware weenie
most of the comms revolution was seeded by Milstar.
Old 7th December 2017, 09:56 AM   #343
traderbam is offline traderbam  Europe
traderbam's Avatar
Originally Posted by Shinja View Post
I simulated rough, simplified circuit of LM317 and plot the loopgain.
Very good. Regarding the circuit in post #325 you might want to add a 330uF across the output and plot the gain and phase. See what frequency the phase margin is 45 degrees (135 degrees of phase shift). Then consider what effect adding a wide bandwidth opamp in its loop will have.
Everything matters.
Old 7th December 2017, 02:24 PM   #344
nigel pearson is offline nigel pearson  United Kingdom
I had to sit waiting an hour for my daughter today so thought out a few ideas. This one looked possible. Doubtless a poor attempt. All the same it did better than it should. I would say no better nor worse than a LM7812 in this circuit. Note it can deal with ripple. It isn't a miracle of off load regultion. Doubtless there are better feedback pair ideas. The idea here is to have some voltage gain. Noise could be better. A higher gain NPN gives 2 dB less ripple ( BC337-40 ). All from the junk box so not selected to be special.
Old 7th December 2017, 04:37 PM   #345
I thought you would like to see what happens with reduced gain and equal voltage out. Not bad for $0.07. for two LED's. Ripple is down by the gain reduction. This seems to show input noise is the larger factor. I might be able to sweet spot it. What a nice project. I doubt 2 hours in total. No nasty things up band. > 2 MHz very quiet.
Old 8th December 2017, 08:33 AM   #346
Finally the dropout voltage. Seems to be 0.9V as I hoped. Note how the Ft of the output device shows at 2MHz of 8MHz last graph. I should have called it a compound pair with feedback rather than feedback compound pair. The PW Texan amp had a similar output stage. If you reference back to my raw 22 000 uF ripple you can see this is genuinely still working. In fact even at 0.6V pd in out it was trying to work. I am too lazy to work out the open loop gain of this pair. Must be very good to get 60 dB reduction at 100 Hz.
I found it not very temperature dependant up to about 50C ( drops 0.1V ). The voltage drops from 11 to 10.6 for 26V in to 12 V in. It can be adjusted if required and shouldn't matter in audio to vary 0.5V. Is this a good regulator? I have a hunch it is. One LED is fine if not chasing 1.5 dB of noise. The way it drops voltage could be useful if living where voltage fluctuates. That extra 0.5V drop could allow more current for a smaller heatsink when at either limit. Unlikely for a preamp to need that. If you use a TIP2955 simple fuse protection should work. Graphs between 1kHz an 8MHz look the same.
Old 14th December 2017, 12:03 PM   #347
New optimum version uses 75K to single LED. Gain resistors 100R and 1K1 gives 12V. Noise -104 dBV ( -125 dB 12V ). Ripple -100 dBV 470 uF or -90dBV 10 uF ( 56R output load ). The use of a cheap capacitor making up for the lack of an op amp. Replace LED 75K by 1K raises noise 4 dB. I speculate a CCS and resistor to replace the LED might be best. Even so 6uV output noise is OK. The simplicity of the idea almost says as easy as a LM317. I kept the 0R33 and 10 000 uF to be consistent with the question asked. I did note good measurements without it.
LM317 load capacitanceHide this!Advertise here!
Using an LM317/Lm337 PCB to make a zener regulated or capacitance multiplier supply doors666 Power Supplies 4 3rd January 2016 03:09 PM
High capacitance vs load on Bridge rectifiers RobertS61 Power Supplies 26 14th September 2011 11:42 AM
Load capacitance ... how to get it halved? jiiteepee Analogue Source 1 26th July 2010 10:04 PM
Amp sim output load capacitance, how much? cbdb Solid State 9 4th June 2009 04:42 PM
Cartridge capacitance load? I have some questions! Kuja Analogue Source 8 24th July 2005 02:18 AM
