LM317 load capacitance
Old 19th October 2017, 09:06 AM   #11
dotneck335 is online now dotneck335  United States
Originally Posted by mchambin View Post
Do as they say on the LM317 application note.
Most of the design engineering I fixed were wacky ideas fixed by just following the application note.
Hence, if anything go wrong, first thing to do, is digging the AN.
On the LM317 application notes, they show a 1uF capacitor on the output. Is that what you are recommending?
Old 19th October 2017, 09:08 AM   #12
Originally Posted by gmphadte View Post
If the input cap is smaller or the output pin voltage goes higher than the input, LM317 will be damaged. One reverse biased diode from input to output will solve the issue. Gajanan Phadte
Yes, I am using the protection diodes recommended in the LM317 datasheet---one around the input/output and one across Vref.
Old 19th October 2017, 09:11 AM   #13
Chris888 is offline Chris888  United Kingdom
Originally Posted by dotneck335 View Post
Such as?
Such as something chosen from the Linear Tech range according to what your actual needs are?
More current?
Less dropout volts?
Lower noise?
Better step response?
There are plenty of other suppliers too.
Old 19th October 2017, 09:12 AM   #14
Originally Posted by traderbam View Post
I can think of some advantages. But it depends on what you are trying to achieve. What are you trying to achieve?
I am trying to achieve the lowest amount of ripple and noise on a regulated supply of +/- 18 volts that will provide 500mA of current. All this at a very minimal cost.
Old 19th October 2017, 09:26 AM   #15
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
If you want to reduce ripple may I suggest that putting a CRC or CRCRC on the input (and a higher voltage transformer to cope with the drop from the CRC will do a lot more than putting a large cap on the output
I do not think that the output cap is going to have any major effect on the noise level.
Have a look here YARPS, finally some progress! - diyAudio Note that this was my first attempt at designing things. An excercise in overkill, and whilst it works I would do things differently today.
There comes a point where chasing lower ripple becomes a bit pointless because the noise output of the LM317 will swamp it
For some insight into the mind of an obsessive person you could check out this thread From LM317 to LT3080 an LTSpice Journey It's all sims, and I haven't got around to starting a layout for a circuit board for the circuit as yet, but it *may* be of interest.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 19th October 2017, 09:32 AM   #16
As a design goal, that has a few obvious limitations.
What bandwidth would you like the noise to low in?
In real circuits, the change in voltage, ringing etc, from a change in load are often much more significant than ripple under a steady load.
Aiming for 'lowest' often brings no advantage. Your amplifiers should have a resonable PSRR. A better goal might be to work out what your amps can reject before the supply makes an audible contribution, then aim for XdB better than that. It may be worth thinking about that across different frequency bands.
Alternately, if you know what your supplies really look like in frequency and time domains, you can optimise your amplifier to work with them.
The regulator is there to cut out low frequency variations.
Decoupling capacitors work at higher frequencies.
It's the transistion between the two that can be tricky....
Old 19th October 2017, 09:39 AM   #17
R.I.P.
put a 220uF electrolytic across the lower voltage setting resistor.
regards Andrew T.
Old 19th October 2017, 10:03 AM   #18
DF96 is offline DF96  England
That is a newbies wish list, not a specification. Until you know what you want to achieve then you cannot know how to achieve it. You need numbers.
Old 19th October 2017, 11:21 AM   #19
traderbam is offline traderbam  Europe
traderbam's Avatar
I'd tend to agree with Wintermute to get rid of it upstream of the regulator.
It depends how far you want to go...how small you want the ripple to be.
Here's a LCR solution (an inductor is your friend) although it might be overkill and more costly.
Example values for 60Hz mains:
C1 = C2 = 4700uF
R = 7.5 ohms, L = 10mH
I estimate a ripple rejection of about 40dB at 500mA.
You have to make sure there is enough voltage across C2 for the 18V regulator...maybe allow 5V. And then there will be a drop across R, say 4V in the example. So you need at least 27V across C1. A 22Vac transformer would do. Make R >3W for margin...it will get hot at 500mA continuous current.
Mind you, an LM317 is specified to have 64dB of 120Hz rejection with a 10uF Adj cap. so you might end up with overkill rejection at 120Hz. However, the ripple isn't pure 120Hz and contains a lot of HF hash. The LCR would definitely crush this.
Everything matters.
Old 19th October 2017, 11:40 AM   #20
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Linear regs should not have any problems with ripple. Low frequencies are what they are designed to handle and they do it well.
High-frequency noise, on the other hand, passes right through them. Perhaps that is where you need to focus your attention if you see issues.
If your load pulls too much current and you see modulation on the reg and you want to avoid it because it's shared for example, then use better local decoupling caps close to your load.
Too many projects... so little time...
LM317 load capacitanceHide this!Advertise here!
Using an LM317/Lm337 PCB to make a zener regulated or capacitance multiplier supply doors666 Power Supplies 4 3rd January 2016 03:09 PM
High capacitance vs load on Bridge rectifiers RobertS61 Power Supplies 26 14th September 2011 11:42 AM
Load capacitance ... how to get it halved? jiiteepee Analogue Source 1 26th July 2010 10:04 PM
Amp sim output load capacitance, how much? cbdb Solid State 9 4th June 2009 04:42 PM
Cartridge capacitance load? I have some questions! Kuja Analogue Source 8 24th July 2005 02:18 AM
