200V Tube Amp Power Supply
Old 31st October 2017, 06:04 AM   #61
LSOJ is offline LSOJ
Originally Posted by JeffYoung View Post
Edcor has a lot of transformers sized for tube gear:
EDCOR - XPWR Series Tube Power Transformers
I browsed, I'm interested in their 175-0-175 68mA transformer. It is perfect for small 200v applications. I was able to design a simple CRC power supply with a couple of 100uF caps and a 4k resistor.
Originally Posted by kodabmx View Post
Or save yourself a lot of time, money, and effort and just use one of these.
DC-DC 8-32V to 45-390V Step Up Power Supply Module High Voltage ZVS Boost Module | eBay
Power it with one of these.
AC100-240V To DC 12V/24V 2A -10A Power Supply Adapter Driver Switch For strip | eBay
You run the heaters from the 12V supply and the rest from the boost converter.
Cheers.
On the present board I'm working with, a dual 6922EH tube headphone amp, I'm using this device with a 24V 1A DC power supply in this device you recommended. It can't seem to keep the charge up.
It uses a 200k resistor to grounds in the form of a voltage divider for floating the filament voltage to +50
Here is also a picture of this setup, and the 1H inductor is not connected.
200V Tube Amp Power SupplyHide this!Advertise here!
50-200V regulated power supply JoeAlders Power Supplies 24 14th December 2011 12:11 PM
Power tube maximum current draw from a power supply razorrick1293 Tubes / Valves 4 4th November 2011 10:48 PM
Power Mod from 100V to 200V on MC2105 Beck81 Solid State 17 29th June 2011 01:26 PM
Looking for 200v-0-200v power tranny eVITAERC Parts 0 3rd November 2005 05:30 AM
200V 50A Fast Recovery POWER Rectifiers kilowattski Pass Labs 7 17th February 2004 04:15 PM
