Should the cap for the bias be a Y rated cap for safety? And, does the value matter? I am thinking because the circuit draws such little current they can get away with such a small amount of capacitance. i.e. Once it charges up there is hardly any ripple because of the miniscule load. I was asking because I have a handful of .1uF 1.5kV rated Russian K42-Y capacitors.
Thanks,
-bird
Thanks,
-bird
No, there is no "human" safety involved here. That said, a Y cap will work, and there will be no noticeable inconvenients.Should the cap for the bias be a Y rated cap for safety?
The value matters a little, because you don't want parasitic modulations caused by the diode's turnoff or the program, but beyond a certain value, there won't be any improvements.And, does the value matter?
With 100nF, you will increase the size of the jolt, should you venture your fingers in the wrong place, and also the damages in case of arcing.
4n7 seems a little light, but I don't think going over 22nF makes sense
I was just worried that if the cap failed short there could be -1kV sitting on the input terminal strip which someone could touch. I just noticed they put the diode backwards in that schematic.
Looks like I am going to have to order some caps then. One speaker had a bunch of ceramics in series that I couldn't read the values of. The other speaker had one cap that reads 681 so I assume it's a 680pF cap and also needs to be replaced.....
