AC Voltage Stabilizer
Old 13th September 2017, 03:35 AM   #31
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
DIY option:
1. Generate 50 Hz signal
DDS Signal Generator AD9833 Module Programmable Microprocessors Sine Square Wave | eBay
2. Amplify it
WONDOM 1X 400W Class D Audio Amplifier Board Compact T-AMP Module Subwoofer | eBay
3. Power this things from SMPS
High quality HIFI 800W SMPS +/-60V LLC Soft switching power supply board AMP PSU | eBay
4. Use some toroid power transformer, backwards. Set 240V by a volume control pot.
Edit: what I found on ePay, just examples. You need an amp and PS that match each other.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 13th September 2017, 03:45 AM   #32
mchambin is offline mchambin  France
Another option: Couple an electric motor to run a generator.
This is how we made 400 Hz AC to test stuff used onboard navy ships in the 60's.
Transistor junction temperature is not transistor case temperature.
Old 13th September 2017, 03:56 AM   #33
sumotan is offline sumotan  Indonesia
Wazzzzz getting to sound complicated. Lol
Btw my brother has a variac laying around,
can that be used ?
Thanks guys
Old 13th September 2017, 03:58 AM   #34
can that be used ?
Thanks guys
Yes.
Of course, it will not stabilize, but perfect to compensate for the average line undervoltage.
Old 13th September 2017, 12:34 PM   #35
DF96 is offline DF96  England
I cannot understand why the OP and the PSU maker both seem to think that this SMPS behaviour is acceptable.
AC Voltage StabilizerHide this!Advertise here!
old voltage stabilizer as possible isolation tranformer ppavone Power Supplies 5 18th May 2017 11:00 AM
The Xreg Voltage Stabilizer rjm Power Supplies 6 2nd February 2010 08:21 AM
D.I.Y car Voltage Stabilizer aka V.s ufo Everything Else 8 7th November 2009 09:47 AM
220V Voltage Stabilizer for home theter yusuf Power Supplies 12 5th April 2007 05:18 AM
ac voltage stabilizer ari polisois Everything Else 9 8th February 2005 03:58 PM
