Let's twist again.
Let's twist again.
Old 18th September 2017, 10:00 AM   #21
R.I.P.
Originally Posted by mchambin View Post
I doubt it can pick much emi because of the low impedance of windings, electrolytic caps and hf caps.
On the other hand, I am sure it can launch much emi because instantaneous currents are huge when diodes as conducting ( for a short time in the periods of the power mains ).
This is why the charging circuit for the PSU capacitors must use separate wires/traces from the wires/traces feeding power to the load.
regards Andrew T.
Old 18th September 2017, 10:04 AM   #22
R.I.P.
This brings another question....How to implement signal ground, power ground and chassis ground ? if not, all confused at a star ground.
A small question inside: With an input via an RCA plug, is the RCA ground at chassis ground OR the RCA ground isolated from chassis and connected to signal ground ?
Don't mix up different circuits.
Consider ONE circuit at a time. Remember that any and ALL current fed from a Source MUST return to that source. Draw that circuit. Find the Flow and Return Routes. Make them close coupled. Do not take any part of that route to some remote star.
Some circuits need to have a voltage reference.
You can add a voltage reference link. But that link must not create a loop.
eg. the input circuit to an opamp or power amplifier needs a voltage reference to the output circuit that feeds AC to the load.
That is a single wire reference link that carries virtually zero current.
regards Andrew T.
Old 19th September 2017, 12:15 AM   #23
Diego Mike is offline Diego Mike  United States
Let's twist again.
Originally Posted by jackinnj View Post
In Australia, however, you twist in the opposite direction.
I believe that would be true anywhere south of the equator.
Which begs the question: What do you do if you live on the equator?
Old 19th September 2017, 07:31 AM   #24
R.I.P.
Turn on the air conditioning.
regards Andrew T.
Old 20th September 2017, 05:46 PM   #25
mchambin is offline mchambin  France
In Australia, everything is upside down, the sun is in the North at noon, they drive on the left side of the road and most confusing, the sun rises in the East and sets in the West just like all over the world.
Transistor junction temperature is not transistor case temperature.
Old 21st September 2017, 07:38 AM   #26
R.I.P.
SA must be different. I saw all the people the right way up.
regards Andrew T.
Let's twist again.Hide this!Advertise here!
What Wires to Twist? WntrMute2 Construction Tips 12 18th January 2017 10:16 PM
Twist B+ and B- wires ? RhythMick Construction Tips 2 30th November 2015 10:04 PM
Heater circuit - to twist or not to twist Rob11966 Tubes / Valves 19 20th July 2008 02:08 AM
which wires to twist? Matttcattt Chip Amps 30 1st July 2003 10:16 AM
