Anyone tried Chinese LT3042 board?
Old 23rd August 2017, 03:20 PM   #1
bugbear is offline bugbear  United Kingdom
Default Anyone tried Chinese LT3042 board?
Given the spec of a LT3042
LT3042 - 20V, 200mA, Ultralow Noise, Ultrahigh PSRR RF Linear Regulator - Linear Technology
this board should be magic - just add a transformer, and get smooth, pure power.
Low-Noise LT3042 Linear Regulator Power Board DC Converter Overvoltage 5-20v | eBay
The components appear to be fairly "obvious"; 4 diodes, a big cap, an LT3042, and a PNP power transistor to handle the power.
I imagine the circuit is very much like the ones shown on page 26 of Linear's spec sheet ("Ultralow Noise Higher Current Regulator with External PNP").
All for 12.59.
Do I dash out and buy one, or is there a catch?
BugBear
Old 23rd August 2017, 03:42 PM   #2
starbender is offline starbender
I have one.
It does not come with a nichicon cap. Some unknown brand.. I replaced unknown cap. Feeding 5v dc to dac analog stage.
It's ok.
Old 23rd August 2017, 04:35 PM   #3
Originally Posted by starbender View Post
I have one.
It's ok.
I have in mind to use it for the same purpose as you, in a HiFiBerry DAC+
Per:
DAC+ Pro - external power supply – HiFiBerry
But you don't sound at all taken with this board's performance. What's it doing wrong (or not doing right) ?
BugBear
Old 24th August 2017, 08:01 AM   #4
CallMeMike is offline CallMeMike  United Kingdom
I've bought my board a few months ago. It came with a NOVER cap and it's used for powering up a DAC.
I have no complaints, it just does the job... However I have not done any other measurements but confirming the steady +5V output.
Old 24th August 2017, 09:07 AM   #5
Was it an upgrade for an existing PSU, or part of a new build?
(i.e. are you in the lucky position to make a comparison?)
BugBear
Old 25th August 2017, 06:49 AM   #6
BugBear
The set-up was/is Raspberry Pi and I2S DAC; the set-up was running an iFi iPower when I tried separate power feed for RPi (iPower) and I2S DAC (Chinese PSU)... The result was a marginal better sound definition (possible 'psychoacoustics' effect on my part) tested on integrated amp + speakers and headphone amp + quality headphones.
Old 25th August 2017, 08:55 AM   #7
That sounds promising enough for me to gamble the 13!!
BugBear
Old 25th August 2017, 01:23 PM   #8
Bugbear,
LT3042 is nice reg. Board follows ordinary schematic. It's better than my other ps boards for sure.. I don't have any measurement or data. Only lt3042 datasheet and board components..
Old 25th August 2017, 01:29 PM   #9
Bugbear,
Yeah - I think the board is this circuit from LT data sheet (attached) with 4 diodes and a cap in front
Thanks for your comments.
BugBear
Old 6th September 2017, 10:58 AM   #10
I asked the vendor a couple of questions, which they didn't answer.
But their (only) reply was the attached circuit diagram (which is lacking a couple of component values). But, FYI.
BugBear
Anyone tried Chinese LT3042 board?Hide this!Advertise here!
Chinese Mono LM1875 Board Twil Chip Amps 53 24th August 2017 08:10 AM
differential-in chinese implementation board ejaouen Chip Amps 1 2nd July 2017 10:50 AM
a chinese amp balancedin board ejaouen Class D 2 31st December 2016 05:12 PM
Why battle with Chinese board manufacturers? Boscoe Solid State 93 25th June 2011 10:23 PM
Chinese LM3886 Board having problems mattthegamer463 Chip Amps 20 13th November 2009 05:46 AM
