pros and cons of monolithic bridge rectifiers for power amp PS
Old 15th November 2017, 10:27 PM   #81
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
with tubes, less is more....the simplest of tube circuits never fail to amaze me....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 15th November 2017, 10:35 PM   #82
scottjoplin is offline scottjoplin  Wales
scottjoplin's Avatar
I would like one day to build a simple tube amp, the SS amp I have at the moment is very complex and I would be interested in a complete contrast. Could your recommend something to drive Jordan Eikonas in the VTL cabinet? I also run it without the rear panel OB
Woofer Assisted Wideband is the New Testament renounce the anachronistic acronym FAST
Old 15th November 2017, 10:46 PM   #83
TonyTecson's Avatar
sorry, not familiar with that...
Old 15th November 2017, 10:50 PM   #84
Basically just a small "fullrange" Jordan Eikona - E J Jordan Designs
pros and cons of monolithic bridge rectifiers for power amp PSHide this!Advertise here!
What are the pros and the cons of those 3 vas ? tessier Solid State 93 30th January 2017 02:53 PM
Voltage Regulator for Class A/B Power Amplifier (not SMPS/SPS) - Pros and Cons tiefbassuebertr Solid State 2 15th July 2013 09:39 AM
Cons / Pros Borat Tubes / Valves 34 1st September 2009 01:52 PM
Pros and Cons of this technique? G Tubes / Valves 35 23rd October 2003 06:37 PM
Pros/Cons Remote Power Supply chris ma Everything Else 22 20th August 2003 02:29 PM
