Hello everyone (excuse the language / translation) I searched the Cyrus PSX (not the R version) electric diagram on the forum but the links I found are no longer active ...... Can you help me to find it ??? ?
Thank you
Vincenzo
vincenzo.cherubini@gmail.com
Thank you
Vincenzo
Following this:
http://www.diyaudio.com/forums/solid-state/94321-cyrus-psx-dead.html#post1108684
and using Wayback machine I got this:
https://web.archive.org/web/20121010180222/http://www.tcaas.btinternet.co.uk/cyrus1ps.gif
I see the transformer is specified as 100VA 3% regulation.
If that is right then they are very unusual transformers. They have specified by regulation instead of by temperature. Very few manufacturers do this form of specification because it makes their transformers look very expensive. But quite legitimate.
Having seen the transformers I suspect they are not 100VA, but much higher VA.
Even a 200VA @ 3% regulation is still a regulation limited specification, rather than the usual temperature specified.
Thanks, I've already tried to open the post's link but it will not work anymore .....
V
