OLDO - Open source power supply modules
Old 28th June 2017, 09:39 PM   #11
ammel68 is offline ammel68  United States
Sin Bin
Can you go ahead and solder the voltage set resistors on this board if I purchase one? I would like 12VDC outputs.
LT3042 DUAL power supply DAC preamplifier headphone amplifier
Thanks.
Old 29th June 2017, 02:26 PM   #12
themystical is offline themystical  United Kingdom
Originally Posted by themystical View Post
I wonder if somebody could advise what is the best way of outputting 1.2V say 400mA from the LT3045 module? Is there a neater way than adding a second in series LDO? Preferably one would want to retain the low noise output of the LT3045? The new ESS dac chips require 1.2V.
Sent from my iPhone using Tapatalk
Sorry must have been having a bad day! Output voltage can be anywhere between 0 and 15V no problem.OLDO - Open source power supply modules
Old 30th June 2017, 07:21 AM   #13
mravlca is offline mravlca  Slovenia
mravlca's Avatar
Originally Posted by Nico Ras View Post
If I understand the PCB then the 4th and 5th PCB has voltage selection thus 0.8 + 0.4 should give you 1.2VDC. Is my assumption correct
Minimum output voltage is 1.4V which is also the refference.
Thanks.
Yes, I can. I think that is also said in the ebay add.
Best Regards,
Aleš
Old 30th June 2017, 06:11 PM   #14
Sin Bin
The way you word it in the Ebay ad is why I was confused.
"Output voltages are set with 0805 resistor (in package are resistors included for 3.3V, 5V, 12V)"
This sounds as if various resistors are included with the board so people can select and solder the one they require.
No problem...I read more into it than needed.
Thank you for your reply.
Old 2nd July 2017, 10:27 AM   #15
mravlca's Avatar
Hi, thank you for your feedback. I have to admit, but you're right. It is not clearly stated buyer can get configured PCB. I will fix that.
BR,
Aleš
Old 4th July 2017, 02:49 AM   #16
Sin Bin
You're welcome.
I admit that sometimes even simple things can confuse me and I'm just not able "to see the forest for all the trees".
I look forward to receiving and trying your LT3042 dual supply.
Old 10th July 2017, 08:26 AM   #17
mabu0815 is offline mabu0815  Germany
Could you please post the BOM for the motherboard RMP here?
mabu
Old 11th July 2017, 10:47 PM   #18
mravlca's Avatar
mabu
Hi Mabu,
please find attached BOM for RMP motherboard.
Aleš
Old 13th July 2017, 06:08 AM   #19
Sin Bin
I received my LT3042 dual supply board a few days ago.
The PCB layout and the soldering of all the SMD's were all first-rate.
After soldering the few thru-hole components included with the board, it worked the first time without any issues whatsoever.
Plus...I didn't have to wait 2 or 3 weeks to receive the board and components like you do with most Chinese sellers.
I hope I can try the LT3045 in the near future if you offer a dual version on Ebay like you did for the '3042.
Old 19th July 2017, 07:30 PM   #20
wushuliu is offline wushuliu  United States
wushuliu's Avatar
Is an unregulated wallwart okay for dc power supply fot the 3045?
OLDO - Open source power supply modulesHide this!Advertise here!
[Open source] TINA The total open source Audiophile Player based on Beaglebone Black DragonWar PC Based 7 18th December 2016 03:31 PM
Open-source firmware and software for the programmable power supply prasimix Equipment & Tools 27 7th June 2016 02:58 PM
FS: SKA GB150D modules and power supply muzza Swap Meet 1 28th November 2011 10:14 AM
Hypex modules and power supply FS tubesguy Swap Meet 3 9th January 2011 02:03 PM
Open call for suggestions on Open Source DIY Audio Design gfergy Everything Else 1 15th April 2007 08:33 AM
