Does the signal current loop around an amplifying device include any local decoupling - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th May 2017, 01:57 AM   #1
TonyTecson's Avatar
Default Does the signal current loop around an amplifying device include any local decoupling
i know it is, but let us hear what others have to say?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 20th May 2017, 03:10 AM   #2
rayma is offline rayma  United States
Draw the AC equivalent circuit. Now put back in the power supply capacitors.
If you have to break any lines to do that, then yes they are in the path.
Old 20th May 2017, 03:57 AM   #3
TonyTecson's Avatar
so are you saying it is not a simple yes or no?
Old 20th May 2017, 04:26 AM   #4
Usually it's a yes, unless there's a regulator circuit, or a current source after the cap.
Some circuits, like a diff amp, draw equal and opposite signal currents at the same time,
so little signal current gets in the supply if they are well balanced. A cathode follower tube
following a voltage amplifier tube is a combination that can have little signal in the supply,
since they also have equal and opposite signal currents.
Old 20th May 2017, 04:29 AM   #5
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Ultimately they are in the signal path but "at the other side of a wall" which is the preamp/power amp itself, which may have better or worse supply rejection.
Completely different from being, say, used as coupling caps between signal source and load.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 20th May 2017, 04:38 AM   #6
TonyTecson's Avatar
thanks guys, keep em coming....
Old 20th May 2017, 06:50 AM   #7
Mooly's Avatar
Best answer I think.
I always argue it like this...
If the PSU cap was directly in the signal path then a DC coupled amplifier would not be able to maintain a DC voltage across the load, or to be able to deliver a low frequency squarewave (say 1Hz) with no apparent droop.
How can that be so if the cap/s are in the signal path ?
Answers on a postcard
Old 20th May 2017, 07:26 AM   #8
udok is offline udok  Austria
They are definitly not in the signal path (at least in my definition of signal path).
They have a secondary task: To provide and filter power for the active parts which
are in the signal path.
Best wishes,
Udo
Old 20th May 2017, 07:40 AM   #9
scottjoplin's Avatar
Since in your question you ask whether they are in the "signal path" rather than the signal path, then I would say "yes".
What came first, the music or the misery? Nick Hornby https://www.youtube.com/watch?v=nSlleE9s9gI
Old 20th May 2017, 07:43 AM   #10
TonyTecson's Avatar
yes, discounting coupling caps which is clearly in signal path....
i posted this in another forum....see if you agree...
take the OPT in a push pull amp, it is biased at 300 volts say and the OPT center tap is connected to a psu filter cap while the outer ends to plates of output tubes, this is dc biasing condition...but what about ac? the center tap at ac acts like the fulcrum in a see-saw. it is at ground zero in terms of ac.....guess what? it is in the signal path....if you can only see that as dc alone, then you are looking at half of the picture, you also need to see in terms ac...just as dc biasing has a + an -, so does ac. it has a loop that can not be broken...
How does the music signal get amplifying current in Class-D ? stephend1714 Class D 3 25th October 2015 12:20 AM
current amplifying phono stage Onvinyl Analogue Source 81 3rd March 2015 05:54 PM
Current amplifying vs. voltage amplifying. roly94 Solid State 20 23rd August 2014 03:18 PM
Bipolar cap as local decoupling ? Eldam Power Supplies 6 9th April 2014 04:37 PM
Current loop based link signal transfer PMA Solid State 12 23rd June 2005 03:46 AM
Copyright 1999-2017 diyAudio
