Power Supply for TDA7293 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 19th May 2017, 12:01 PM   #1
Default Power Supply for TDA7293
Hello Diyers
I want to build an active 2.1speakers system. Am intending to have three 4ohms drivers (full range, mid range & tweeter) in left speaker cabinet and similarly in the righr, amplifing each driver with a separate TDA7293 amp.
Is it possible to use one power supply, to power the three driver in each cabinet?
Old 19th May 2017, 01:37 PM   #2
scottjoplin's Avatar
Hi. Yes you can use one power supply since the amplifiers require the same voltages. What I don't understand is why you want to use a full range, a mid range and a tweeter.
Is this what you meant, not a woofer instead of the full range?
What came first, the music or the misery? Nick Hornby https://www.youtube.com/watch?v=nSlleE9s9gI
Old 19th May 2017, 02:44 PM   #3
Thank you Scott
I will have a woofer separately.
Would the use of a full range and midrange be a duplication of resources in such a configuration?
Old 19th May 2017, 04:59 PM   #4
Yep. Three way speakers are usually woofer, midrange and tweeter (WMT). Sometimes they are MTM (technically not 3way), I've yet to hear of a FMT...
Which power supply for a TDA7293 board? Coliban Power Supplies 3 3rd February 2016 11:07 AM
How to reduce voltage on supply rails - TDA7293 Steadysupply Chip Amps 10 18th March 2014 01:51 AM
tda7293 power supply voltage sonyzz Chip Amps 50 19th January 2014 09:26 AM
TDA7293 x3 parallel mono_power supply delga Solid State 11 31st May 2013 07:22 PM
Bridged TDA7293 single supply Vibeguy Chip Amps 0 15th July 2011 09:57 PM
Copyright 1999-2017 diyAudio
