That is not what happened.For many years now the voltages are changed.We had 220V and the UK 240V ,then along came Euromadness, now everyboddy is supposed to get 230V..............
We now have the "harmonised" mains supply system.
That requires the manufacturers of mains equipment to be sold in the EU to operate correctly and safely with any voltage within the range of the harmonised supply, i.e. from 216Vac to 253Vac.
The supply voltage on the mains wiring has not changed.
The European Mainland still operates @ 220Vac +- a tolerance
The UK still operates @ 240Vac +- a tolerance.
However, there is a small gain in efficiency for the electricity suplliers, if they reduce the current and increase the voltage of transmission.
That small increase in efficiency is extra profit for the power generators/transmitters.
Thus there is a tendency to increase the voltage of the mains supply.
The UK regularly operates around the 245Vac.
I hear from out North American Members that they are seeing 115 to 125Vac on their house supplies.
Have a look here,That is not what happened.
Complete list: Plug, socket & voltage by country - World Standards
Mona
Just google for. There will be many examples.
That is not a reliable way of testing the mains. I used one before hanging a new lamp. My "mains phase tester" lit up even when the phase was switched off.
And did you find a better way to test the phase?
I agree with you on that but professional tool would cost orders of magnitude more.
The 230Vac stated for UK is the "harmonised voltage" agreed for the EU.
That is the nominal voltage that applies to all the electicity generators and all the equipment manufacturers must adhere to.
But the range of voltage is still 216Vac to 253Vac
The UK is still on a nominal 240Vac. The UK did not change all their generators nor all their transformers.
It the same for the European Mainland, they still operate at a nominal 220Vac and they too did not change all their generating equipment and transformers.
Surprising that the Phase to Earth and Neutral to Earth are not half the Phase to Neutral value.live measurements:
P/N:220v
P/E:127
N/E:127
I wonder if that indicates a measurmeent error, or an excessive voltage on the Earth that thus reads 127Vac instead of 110Vac?
In Holland, the voltage has gone up. Where you would measure 220-224V it is now above 330V.
I would check with the power company and/or building owner to confirm if this is correct.
done, let's see if they reply me ;-)
Contractually, they have to supply 230V+/-tolerance between two, or several pairs of wires. The rest is immaterial, unless you have a three-phase contract, so move along, there's nothing to see (or pay for an upgrade, if it is even possible)done, let's see if they reply me ;-)
Rookie thread I told you ;-)
I try to understand...
I've only three wires coming from the street (first pic)
And then the three goes in a black box and then 4 wires come out to electric board.
So three phases and a neutral I guess as earth is separated....
> he has DELTA type connection as pointed earlier by Elvee
Agree. Worked out from notes and pictures.
He has three legs of a wYe, apparently two live wires and the neutral/earth.
The colors are not according to current EU practice. I can't figure what older standard they may come from.
As Belgium is 220V-240V, the 127V sides are of no use.
The 220V across the two hot should be fine power.
There is a slight benefit in the nearly "balanced" power.
There is a residual environmental potential because the mid-point of the two legs is not the same as "ground". However it is much smaller than the 60V mid-potential in all US work.
I have no idea why transformers hum.
live measurements:
P/N:220v
P/E:127
N/E:127
That is absolutely correct for a three phase system. There is 120 degrees between each phase. 1/sin(120) x 110 = 127.
What is a bit more bothersome is that a transformer rated for 240 volts at 60 Hz should be fine at 200 Volts at 50 Hz. Not so even at 220 volts. However if it is rated for 220 volts at 60 Hz it will start saturating at 183 volts.
As your transformer is seeing 220 volts from what appears to be a proper service the issue is most likely one of how the transformer is rated.
- Power Supplies
- Mains power: how to recreate a phase?
