Very likely the reason is you have oscillation. A wide bandwidth opamp driving a MOSFET gate means there's significant capacitive load. Ah and now I notice your snubber has a 10uF capacitor in series with 2R4 so you can be fairly sure you have oscillation even without the MOSFET in circuit. How did you arrive at those values for your snubber network (R8,C8)?
http://cds.linear.com/docs/en/application-note/an104f.pdf
I used fig 6. from this article.
Pins 2 and 3 are reversed in your drawing. Pin 2 is -ve input not +ve
I know it's reversed. It doesn't change anything.
Fig6 and none of the others have pin numbers associated with the inputs.http://cds.linear.com/docs/en/application-note/an104f.pdf
You appear to have invented some pin numbering.
Did you look at the chip datasheet?
That article shows an LT1210 whereas you've changed that. What makes you sure your substitution isn't going to break the circuit? The specified part has provision to improve stability into large C loads (and the capability is being used, along with its substantial drive capability) which yours does not.
There are two datasheets involved giving diff. nbrs.I looked at the datasheet and it's OK. all pins are correct.
Can't you adjust R11 ?
Mona
- Power Supplies
- OP AMP input error (LM7121)
