How to calculate transformer secondary resistance ?
Old 20th March 2017, 01:11 PM   #1
franciscano is offline franciscano  Romania
Default How to calculate transformer secondary resistance ?
Hello everybody, i wonder if there is way to calculate the secondary R of a transformer, if you know the output V, off load V, and I rating ?
Old 20th March 2017, 02:13 PM   #2
sesebe is offline sesebe  Romania
You cannot calculate because it is connected to the tYpe of transformer....but if you can do some measurements you can calculate using the measurements results.
Old 20th March 2017, 02:45 PM   #3
DF96 is offline DF96  England
Do you mean secondary DC resistance? If so, calculate using knowledge of the wire used and length. Or measure it.
Do you mean effective secondary resistance? If so, calculate from measured primary and secondary resistance and voltage ratio. Or from measured voltage droop at a known current.
Secondary resistance is one of those things which if you know why you want the number then you know how to obtain the number.
Old 21st March 2017, 02:19 AM   #4
PRR is offline PRR  United States
PRR's Avatar
Same as any Ohms Law problem.
Difference of Voltage, divided by Current.
Example: Rated 12V at 1 Amp, 15V at no load. 3V difference. Caused by 1A current. 3V/1A is 3 Ohms.
This is NOT the "secondary resistance", but the sum of primary and secondary resistances (and also leakage inductance). Which is usually what you really want to know: the total loss. How this splits between primary and secondary is usually only important to the transformer designer.
Old 21st March 2017, 02:32 AM   #5
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
You can make some estimate of the secondary resistance from only the on-load output voltage and the open circuit output voltage. As above in PRR's post, the secondary resistance will normally be half of the resistance measured from the voltage drop. The other half is the transformed primary resistance (primary resistance divided by turns ratio squared).
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 21st March 2017, 04:39 AM   #6
wg_ski is offline wg_ski  United States
Most of a transformer's voltage drop under load comes from leakage reactance due to imperfect coupling between pri/sec. That models as an equivalent series inductance, not resistance. The same laws of reflected impedance between pri and sec apply - it's just there's a "j" in there. Little bitty five watt trafos may be dominated by resistance, but anything you really want to make an amplifier with won't be. With really big power trafos they rate them in "% reactance" because the resistive part is vanishingly small.
Old 21st March 2017, 05:00 AM   #7
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
i do copper loss testing aka short circuit testing of my traffo builds....
i test them in increments of 1 amperes or up to rated primary current....
i use a variac and a home brew voltage and current meters...
the variac supplies low voltage to the primary, while all secondary windings are shorted together...
very straightforward to use, just read the voltage at the rated current...
this is a non destructive test.....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 21st March 2017, 06:48 PM   #8
PRR's Avatar
Do you (or anybody) have data about wg_ski's statement "Most of a transformer's voltage drop under load comes from leakage reactance..."?
Reactance matters, why is why I edited it into my post.
At 10KVA and up it becomes dominant. (In part because of the economics of large power: resistance is real loss while reactance is just sag, and useful to limit fault current into a short.(
Below 1KVA, I would expect many transformers to have low reactance. However there are many ways to wind the little beasts. Primary over secondary is well coupled. Pri and Sec on separate legs is poor coupling, and often done for safety, shape, or to reduce HF noise.
Old 21st March 2017, 11:42 PM   #9
TonyTecson's Avatar
i have no data on that as i do not know how to measure it....
Old 22nd March 2017, 02:50 AM   #10
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
X/R ratio is related to kVA in general. Maybe not linearly, but perhaps more exponentially. The IEEE Red Book has graphs of 'typical' X/R ratios, but this is pertinent specifically to transformers that rate in the MVA's.
Point being, small dry type transformers have X/R ratios around 1 at about 15 kVA three phase, and it climbs to approx 5 when you reach 1000 kVA. From there you tend to find a limit around 20-30 for the really big boys. Transformers that rate in VA are dominated by resistance, and this I have tested up to around 500 VA single phase. Anything in home audio will be mostly resistance, regardless if you are talking toroid or EI. Sure, EI will have more relative leakage, but it's still small in comparison to the resistance that contributes to overall impedance Z.
How to calculate transformer secondary resistance ?Hide this!Advertise here!
Calculate Resistance from Z and Phase? kouiky Solid State 3 8th December 2013 09:01 PM
6550 plate resistance in triode mode? Calculate? Koektrommel Tubes / Valves 4 5th August 2013 01:43 AM
Transformer secondary resistance argonrepublic Power Supplies 7 1st February 2013 10:11 AM
How to calculate mechanical resistance added by enclosure. SoulMagnet Subwoofers 0 10th January 2012 07:25 AM
calculate thermal resistance of alumimium heatsink bigpanda Everything Else 1 17th September 2008 10:14 AM
