NKK
I like the NKK M2100 series. Round switches are easier to use for DIY since you can just drill a hole instead of figuring out how to make a nice rectangle.
http://www.nkkswitches.com/pdf/M2100Toggles.pdf
(this uses NKK rocker and toggle...from the days of my illumination phase...)
This parts fits a 7/8" hole, which is the size of the chassis punch for tube sockets I already own. Excellent.For ease of DIY installation / panel fabrication, I'm partial to appropriately rated round rocker switches myself. Plenty of options such as metal, lighted plastic, backlit, shiny or black, etc.
Such as:
http://www.mouser.com/ds/2/833/Rocker_RR_PPR-1075676.pdf
Rocker Switches DPST ON-OFF 10A BLK
Mouser # 540-RRA32H3FBBNN Minimum Qty: 1 @ $C 2.23 as of 12 March 2017
Mfr [ZF] # RRA32H3FBBNN
http://ca.mouser.com/ProductDetail/ZF/RRA32H3FBBNN/?qs=sGAEpiMZZMsqIr59i2oRcortqEmGFdBDoAnuzoQuxcQ=
You can also consider pushbutton switches in a round hole panel mount configuration as well.
Lazzzzzzzzyyyyyy.........This is plenty good enough RMS1016 | Rotary Switch, 2 Way, Solder | Lorlin
- Power Supplies
- Which power switch???
