Let's discuss ZM's Good Gemini shunt
The shunt was shown as a brother of Iron pre and Iron pumpkin and was partnered with a capacitance multiplier.
http://www.diyaudio.com/forums/pass-labs/293169-whats-wrong-kiss-boy-19.html#post4883680
I would like some help discussing its Vout range and load current limits to see if it could fit any other projects like the B1, the BA-3 or even digital stuff.
To quote NP
Of course you can bias this circuit higher if you wish – 100 mA bias is perfectly OK as long as you properly heat sink Q3 and Q4, and if you are crazy (like me) you can experiment with higher bias, remembering that the parts are rated at 25 watts
Now where is my crazy hat....
Anyway, I did some reading.
If I understand this, R3||R4 sets the constant current output using
I = ~(Vbe on)/Rtot
right?
And the divider R7/R8/R9 sets the voltage?
here it is - for BA3 FE , +/-24Vdc , programmed current 120mA
yup , you got it , for programming current and for setting output voltage
however - when changing output voltage , one must maintain optimal currents both through reference diode and through voltage divider for error amp (R7,R8,R9)
reg itself is simple ...... pretty much everything is covered in :Pumpkin: & Shunty CookBook , simply because GG is smaller bro of Shunty , but not less effective
consider one important thing , pretty much covering all active electronic stages , but especially supply regs - PCB design is of same importance as circuit itself
BD139/140 are good up to 5W , if cooled properly
above that , go to BD239/240
xformer - everything bellow 56Vct (2 x 28Vac) is on your own risk, considering regular mains voltage sagging of 10% or even more
15VA per channel , 30VA for both , as minimum
first elco caps after bridge can go up , rest of them no need or counterproductive
if you want 200mA for programmed current , just change those resistors to
5R1 // 9R1
everything else as is
diss on BD :
(input V - out V) x programmed I
diss on IRF :
out V x (programmed current - load current)
Reactions: andynor
aha , forgot to say
you mentioned digital , as possible area of use
nope ....... due to construction , even with possibility of major re-work , I wouldn't go bellow 10V for output voltage
simply - matter of choice ...... for 5V and similar , we need different approach
diss on BD :
diss on IRF :
Changing BD139/140 to BD239/240 is not a good idea.Then you have to get smaller R1,R2 (need more base current) too, making poor regulation.
That's why I put darlingtons for more current, the resistors can stay as is.
Mona
you're right , I forgot to mention change in value of these resistors
however , 5W is more than enough with BD139/140
above that , I would consider something in range of BDX53/54 family
in any case , this is not exactly swiss army knife , every major change (meaning Vout/I out) demands necessary analysis , to maintain proper phase behavior of reg
