Power soft start board / amp delay soft start board   what is it ???
Old 18th September 2016, 01:54 AM   #1
thesaintxxx is offline thesaintxxx  Thailand
Default Power soft start board / amp delay soft start board what is it ???
what is it ??? thk
Old 18th September 2016, 03:52 AM   #2
Old'n'Cranky is offline Old'n'Cranky  Australia
Is the search function no longer working ?
Old 18th September 2016, 03:54 AM   #3
Tromperie is offline Tromperie  Australia
What is the question?
Old 18th September 2016, 04:56 AM   #4
Default 1000W 220V Power Amplifier Protection Board Power Delay Soft Start Circuit
https://www.aliexpress.com/item/1000...999.272.R9Sl5d
Old 18th September 2016, 05:30 AM   #5
vzaichenko is offline vzaichenko  Russian Federation
vzaichenko's Avatar
what is it ??? thk
Normally, power amplifier's PSU has got a high-power transformer (500-1000 VA) and impressive bank of DC filter capacitors (100-300 mF). Its power-on requires gradual aproach - first, you connect PSU to the mains via an inrush resistor, limiting the current, charging the filter capacitors. After a few seconds delay, inrush resistor is shorted and PSU operates at full power.
In many cases, soft start board is combined with protection board. During the power-on sequence, the speakers are disconnected from the amplifier's output. As soon as power-on is complete (one more delay runf off), the board connects the speakers to the amplifier.
During the operation, protection circuit monitors the amp for such events as:
- DC offset at the output;
- Output stage over-current;
- Heatsinks over-temperature;
- AC failure (mains blackout).
In case of trouble, the board disconnects the speakers and shuts down the amplifier.
See the info on soft start / protection boards here:
21-st century control boards
And here is how it all started:
21-st century boards thread
Valery
If you can't explain it simply, you don't understand it well enough (c) Albert Einstein
http://vzaudio.com/
Old 18th September 2016, 06:38 AM   #6
thk , i am starting build mx50 se amp board with +
NOVER Electric Capacity Rectifier + Loudspeaker AIO Board
Description:
- Adopting original 2510 rectifier
- Electrolysis capacitor signal main loop adopts Taiwan brand, main filter adopts NOVER professional capacitor10000UF*4/50V, guarantee the constant driving support
- PCB adopts 1.6mm thick two sides board, 2.0 oz copper thickness, tin plated machining, good current passing performance, high quality of PCB board
- Adopting 12A large current imported relay, more stable performance, more durable
? is i need to add Power soft start board / amp delay soft start board or not for safety reason
thk very much againd
Power soft start board / amp delay soft start board   what is it ???Hide this!Advertise here!
Power Supply Soft Start Board (V3) Jason The diyAudio Store 284 20th June 2018 08:16 PM
Class A soft start delay temperature protection board (with switch function) deafbykhorns Solid State 7 8th November 2015 04:44 PM
Power Supply Soft Start Board (V2) Ana The diyAudio Store 194 18th September 2014 08:42 AM
Soft Start PC Board organics1 The diyAudio Store 2 29th March 2013 04:18 AM
Commercial Soft Start board wytco0 Parts 0 5th August 2005 04:26 PM
