Hello
Im planning to build a cheap amplifier but my matter actually is the power supply
The amplifier board is a tas5630 (TAS5630 1200W 2 0 High Power Digital Amplifier Board | eBay) and the supply
is New DC DC 600W 10 60V to 12 80V Boost Converter Step Up Module Power Supply | eBay
or 200W 6 35V to 6 55V DC DC Converter Boost Charger Power Converter Module F5 | eBay and those boost
module will certainly be mounted on a pc 12v 350w transformer .
But im pretty sure both supply wont be enough
So here is my question , if i put some condensator (5 Pièces 2200?F uf 63V Condensateurs Chimiques Electrolytiques | eBay)
at the boost ouptut do you think it will be enough to make the amp work at 80% of it power or could you tell me a cheap power supply that could make
it work at atleast at 80% of that amp board
Sorry for my rusted english -_-
48v rectifier supplies for telecoms can get you a lot of power for a good price.
Ok thank you for the answer
rectifier price are also a bit high :s
i found DC 48V 5A Regulated Switching Power Supply AC 220V 110V to 250W DC48V 5A s 250 | eBay look good also for the price may be better i go on this ?
Where is your power coming from?
A 12V battery or from the 110/120Vac mains?
From an old PC power supply rated arround 350w 12v
This will work nicely.
You can also go even cheaper with even less power like this one:
AC 110 220V to DC 48V 3A 150W Volt Transformer LED Strip Switch Power Supply | eBay
Let´s see if I understand you:
1) You want to build a 1200W power amplifier.
2) You want to power it from a 600W up converter.
3) You´ll feed such up converter from a 350W PC power supply
4) that is the *total* power rating, considering all outputs.
Since the main one is the 5V one while 12V is more of an auxiliary output , I doubt you can get more than 100W out of it ... if that much
Ok, ok, where´s the :
Since 2005, 12V is the main while 5V is more of an auxiliary output
Hard to say but true xD , i wont get my 80% of rate to get the desired power i would need arround 48V 20A ++ , i was looking like car battery but car battery have 45A +++ of power coupled on boost , PC supply have 12V 10/15A output so i should really go for rectifier then may be
OK, let´s do some Math and go backwards, to see what you *really* need.
1) amp claims 1200W output.
No RMS specified, just some vague "2 * 600W / 4 Europe 10% THD"
Since it´s dubious at best, let´s see what it´s actually capable of, in the most optimistic way:
2) it needs +48V single supply, meaning it´s probably bridged output.
Supposing the supply is perfectly regulated and those 48V are stable, and counting on (optimistic) 2V drop on semiconductors, we have 46V peak available.
Which means you have 32V RMS available , which mean:256 W RMS per channel into 4 ohms, so 500W RMS total.
3) amplifier 88% efficiency so power absorbed from supply is 500/0.88=570W
4) since supply voltage is 48V, it must supply 570/48=12A .
Since udio power amplifiers are often clipped and switching supplies do not like being asked more current than expected (lots of self protection, overvoltage and overcurrent sensors which may shut it off in the middle of something) so I would but a supply with *at least* 16A capability, wouldn´t find 20A an exaggeration, just reserve power.
In a nutshell: cover the amp actual needs and avoid chaining lossy stages in the middle, get the straight supply for it.
Ok thank you for your information which are really usefull
- Power Supplies
- Need help Please
