im using psu board with dinky 1n4004 diodes in them, double bridge mode. and the tranformer is 200vac EI.
I have two setups like this and only difference is that on setup A the transformer is not varnished, (i meant to do it myself later) and has only one secondary tap of 0,27v, where as setup B has varnished tranformer and secondary taps of 0,9,12,27v.
on setup A, the 1n4004 diodes on the PSU spark and blow whenever i turn on the amp.
setup B runs fine, even when i transfer the PSU from the setup A. so i'm sure the difference of the transformers is causing the issue. board from setup B does the same thing in setup A
What is the issue?
and why is it happening?
thanks in advance.
What is the issue?
thanks in advance.
I guess the wording in post #1 is open to interpretation but this reads like 'Amp A has fault that is blowing the PSU'.
PSU A and PSU B boards are proved OK in amplifier B. Q.E.D. amplifier B obviously works.
PSU A and PSU B boards self destruct powering amplifier A. What about amplifier A ? Has that been proved good.
on setup A, the 1n4004 diodes on the PSU spark and blow whenever i turn on the amp ...
where exactly is the power switch located ?
- in front of trafo between mains and trafo
- between trafo and rectifier
- between rectifier and reservoir cap
- between caps and amp ... ?
double bridge mode is what ? ... 4 diode Graetz ... ?
how many microfarads behind bridge ? maybe 0.x ohm requ'd if 1000's of uF
any connectors involved - maybe different between setups or wire gauge different ?
Is there any amplifier? I see nothing referring to them.
- Power Supplies
- diode damage from inrush current?
