Meanwell EPS65S Series Power Supply
I purchased a Meanwell EPS65S-24 power supply from Mouser to use for a small class D amplifier.
The hookup instructions show AC power being applied to AC/N and AC/L. I'm assuming AC/N is for the neutral lead. However, they do not show any connection for earth ground.
The strange thing is they have a two pin connector in a three pin sized holder. They could have easily used a 3 pin connector and provided for an earth ground connection.
Has anyone used these power supplies? I will go ahead and wire everything up. I am somewhat concerned about EMI with no earth ground. Maybe they are counting on the neutral line to perform as a ground. They do show an EMI filter in their block diagram on the data sheet.
