Help with batteries for Blutooth Player - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 7th July 2016, 12:08 AM   #1
benniehanas's Avatar
Default Help with batteries for Blutooth Player
Hello all,
I need help with the battery's for a bluetooth player for my wife's birthday. I want it to be portable as possible. I need to supply 24v @ around 6amps using batteries. The ones I am thinking of are below:
Tenergy Industrial Grade D Cell Rechargeable NiMH Battery 10000mAh
Specifications: • End volt of discharge: 1.2 V • Maximum discharge current: 5C
I was thinking I needed to wire them in series as well as parallel. I don't know how many of these I would need though. It will be a 2.1 system with 2x "Tang Band W5-1611SAF 5" which are 28w RMS and 90db efficient, and possibly one Dayton Audio DCS205-4 8 which is 150W and 88db efficient. Another sub I could use is the Tang Band W6-1139SIF which is 50w and 83db efficient.
I am thinking I would need a voltage doubler circuit inbetween the batteries and amp to raise the voltage and lower the amps out to the amplifier. I am reading books on building circuits like crazy and this stuff isn't getting easier yet for me. Any help would be great.
Old 7th July 2016, 01:57 AM   #2
DUG is offline DUG  Canada
wow
But in the description it says: "The 5000 mAh capacity offers robust performance under load."
Good luck.
There are 12V to 24V boosters on e-bay...they have been mentioned somewhere in DIY...possibly in the boominator thread.
Actually the boominator thread should be where to look for ideas.
Getting 144W out of D cells might be a stretch.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 7th July 2016, 02:19 AM   #3
AllenB is offline AllenB  Australia
I think that efficient speakers are worthwhile here.
Inexpensive B+ Batteries mashaffer Tubes / Valves 10 10th April 2016 07:34 PM
Do batteries still rule? Dr.H Power Supplies 3 11th July 2012 11:30 AM
LEDs and batteries cliffforrest Construction Tips 9 19th October 2011 04:35 AM
STK4141 on batteries Zoodle Chip Amps 17 12th July 2009 11:23 AM
Can you recomend me batteries? lagoausente Power Supplies 6 27th December 2006 05:18 PM
Copyright ©1999-2017 diyAudio
