Variable power supply for tube amps
Old 1st May 2016, 07:14 PM   #1
morelius is offline morelius  Spain
Default Variable power supply for tube amps
I like to design a tube amps for guitar and bass, I need build a variable power supply to work with my prototypes.
Someone had a schematic o recommendation?
I hope that I don't repeat a thread, but I don't find one about this question.
thanks for all replies
Old 1st May 2016, 08:25 PM   #2
jazbo8 is offline jazbo8
jazbo8's Avatar
Search for variable HV supply in the Tubes forum and you will see quite a few threads.
Old 1st May 2016, 08:33 PM   #3
jackinnj is offline jackinnj  United States
jackinnj's Avatar
This is a floating variable hv regulator from the new "Art of Electronics" -- the 500k potentiometer controls the voltage from 1 to 450V
Old 1st May 2016, 09:43 PM   #4
Hi
ok , i will make a new research, i didn't use the right words.
thanks for the schema jackinnj,
i have a question, can i use a electrophoresis power supply or this isn't advisable?
Old 1st May 2016, 11:11 PM   #5
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
* YES
* NO
* MAYBE
* YES BUT .....
* NOT IN YOUR DREAMS
pick one.
Now for a real answer, you tell us what an electrophoresis power supply is, specially what voltage/current it can supply.
Design/make/service musical stuff in Buenos Aires, Argentina, since 1969.
Old 2nd May 2016, 08:01 AM   #6
yes, I must say the specifications
I need a variable 600v - 200mA HV supply.
I was reading a thread about this, but all models are too old or only in USA. Also, I see that some electrophoresis supply doesn't work properly (spikes, etc...).
I can build a power supply, but I don't know any project of any schematic.
Old 2nd May 2016, 08:08 AM   #7
jazbo8's Avatar
You can make a very simple and useful HV supply with just a variac, an industrial PT (say 230V to 480V), a bridge rectifier and some filter caps. You don't really need a regulated PS for testing guitar amps...
Old 2nd May 2016, 10:34 AM   #8
DF96 is offline DF96  England
Build a PSU with two sections fed from one secondary: cap input (DC out ~1.4 x secondary AC RMS), and choke input (DC out ~0.9 x secondary AC RMS). That gives you two voltage rails. I did this and have approx 200V and approx 300V to play with. You don't need more accuracy than that for playing with valve amps.
Regulated supplies are more difficult to design and build than audio amplifiers! And they introduce complications like reactive output impedance which can mess up the amplifier you are working on.
Old 2nd May 2016, 03:23 PM   #9
jackinnj's Avatar
I posted the design using an LT3080 because it's very straightforward and can be built with a minimum of expense. (The LT3080 is $4.40, a 2W 500k pot around $11). You'd probably want to insulate the shaft of the potentiometer.
A bode plot via LTSpice would be a helpful sanity check.
I use a Variac as jazbo8 suggests, but Variacs are pretty expensive outside the US. The great thing about a Variac is that you're not burning a lot of energy in the pass element.
Old 2nd May 2016, 11:05 PM   #10
Thanks all people for the replies,
I'm newbie and i need a recomendation for variac please. I don't find any variac whit 450 to 600V output.
Variable power supply for tube ampsHide this!Advertise here!
Simple Variable Tube Power Supply Sal Brisindi Tubes / Valves 18 3rd October 2016 11:02 AM
Variable Power Supply Bibio Power Supplies 4 16th October 2015 05:17 PM
Building A Really BIG Variable Tube Power Supply. kimbal Equipment & Tools 3 26th October 2013 11:12 AM
12 volt power supply for tube amps caraudionut Tubes / Valves 9 27th April 2007 04:04 PM
Digital Variable Power Supply jleaman Digital Source 13 13th April 2004 11:09 PM
