Would someone please sense check my calcs ? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 29th April 2016, 11:28 AM   #1
Default Would someone please sense check my calcs ?
Hi all. Build of my phono amp is now complete and I'm drawing up a set of tests to work through;
1) unpowered connectivity tests
2) powered, switched off
3) powered, heaters only
4) powered, heaters plus HT
I've built a series lamp limiter along these lines and tested that too.
http://golbornevintageradio.co.uk/fo....php?aid=12296
I've calculated my expected current draw as follows and would be really grateful if someone could check me (first real build).
HEATERS:
4 valves (2 x 12ax7, 2 x 6922) drawing 300mA each = 1.2A total
Transformer secondary is 9V x 1.2A = 10.8 VA
Transformer primary is 240V : so expect (10.8/240) = 45mA draw
HT: Diagram attached if clarification is needed
B+ and B- each drawing approx 35mA (valves plus bleeders) total of 70mA
Transformer secondary is 300 - 0 - 300
70 x 300 = 21 VA
Primary is 240V : so expect (21 / 240) = 87.5mA
So in total I'm expecting a current draw of around 135mA ish
A 60W bulb will draw 250mA, so if all is well the bulb should see around 50% of it's rating.
I've no idea how much the draw has to drop through a bulb before it dims - but I did test the limiter using a bedside lamp with an identical 60W bulb and they both dimmed. Under those circumstances I'd expect the voltage drop over each to be about half. Since a bulb's resistance will vary with temperature I guess that doesn't mean each lamp had 125mA going through it. I guess I could always measure it !
Old 29th April 2016, 04:05 PM   #2
CORRECTION - This is the correct diagram, however I don't think it will be needed. It's the VA calcs I need checking.
Old 29th April 2016, 04:20 PM   #3
infinia is offline infinia  United States
infinia's Avatar
what is the total VA of the XFMRs connected? I'd use overrated transformer windings esp on filaments.
the dim bulb is only used for current limiting under fault conditions , not operational duty. once normal operation is confirmed override the bulb. more or less a 75-100W bulb works for most needs.
I'm no expert in current fed HV supplies but they need constant load current under all conditions or they may go south in a hurry. isn't there a late /early start up /off sequence for them?
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 29th April 2016, 04:54 PM   #4
Pafi is offline Pafi  Hungary
The calculation is more or less OK.
Old 30th April 2016, 09:01 AM   #5
Your 0u22F||220r network between Chassis and Power Ground will not pass a Mains fault current.
imagine a 1000Apk fault current trying to pass from Power Ground to PE to blow your mains fuse.
What effect will your network have?
Why have you specified 12W? What's wrong with W?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 3rd May 2016, 04:24 PM   #6
I put that network there as I drain several shields to earth and didn't want that noise going to HT/signal ground. I specified a high wattage because I wanted to make sure a small value resistor wouldn't burn out if the worst happened. I picked up the values from research, but thinking them through surely higher wattage is better there ?
Shorts to the chassis bypass that network.
Shorts to HT/Signal ground (mains transformer centre tap) would go via that network. Say for example the mains transformer shorted putting 300VAC (RMS) to HT ground. 300v / 200R = 1.3amps. That's 409watts. hmmm - however why is it made better by using 1 quarter watt ? In this scenario either;
1) the primary fuse on the transformer would blow (1.3 amps on a 300V secondary / 240 = 1.7 amps on primary - the fuse there is 250mA)
2) the resistor would fry leaving no path to earth
What's the right answer for this ? Remove the network and not worry about shield RFI noise getting to ground ?
Old 3rd May 2016, 04:39 PM   #7
I quite like the explanations given by this guy ...
http://www.valvewizard.co.uk/Grounding.pdf
but re-reading that I notice that he also includes high-current diodes in anti-parallel "to
bypass more serious fault currents, thereby ensuring any fuses will reliably blow".
Old 3rd May 2016, 04:53 PM   #8
Thank you
Old 4th May 2016, 08:51 AM   #9
The requirement is to protect the Chassis by making a direct connection from chassis to Protective Earth.
A subsidiary requirement is that all exposed metal, or conductive, parts should be connected to the Protected Chassis.
Take your RCA barrels as an example.
If some catastrophic failure allowed a mains wire to touch the RCA from the inside, or down the interconnect from a faulty double insulated item, then that mains will make much of the audio circuits LIVE.
Touch any part of those audio circuits, maybe the speaker lead, or another RCA barrel, and you get shocked.
Take the fault to Chassis and the Protective Earth will blow the mains fuse.
BUT !!! you have put in there a fusible link (220r 12W) that will not pass the 1000s of Amperes of fault current that will normaly blow the mains fuse very quickly.
You must provide a path for the fault current to get to the chassis.
Do more research. The answers are all in this Forum, but I'll point you to my posts, or to ESP, (he copied the Forum's ideas).
The resistor does not benefit from being rated at watts, a few tenths of a watt is enough to take interfence current (micro-amperes or nano-amperes) to chassis.
The resistor dissipation during a fault incident is predicted with the formula P=V/R
for 240Vac and 220r you get 261.82W
If you use a more normal value from 1r0 to 22r then a 10r would be required to dissipate 5.76kW and would pass ~26Aac.
How quickly would the mains fuse rupture while passing that very hot 5.76kW resistor?
What voltage would be across the internal and exposed conductive parts while you wait for the mains fuse to blow?
There is a further requirement (at least in the UK) that the voltage on the exposed parts must not exceed some preset value during the fault incident. (I seem to remember that in the UK that value is 50Vac)
This is normally designed into the house cabling and determines the maximum resistance between the fault touching point and the Distribution board via the Protective Earth wiring.
Your 220r is inside that route. It will fail that requirement !
If you decide to go a different way with protecting the users of your mains powered equipment, then it is incumbent on you to research the risks and find methods to reduce those risks. Or you go to jail when you kill someone.
regards Andrew T.
Old 4th May 2016, 09:40 AM   #10
Ok thanks Andrew. I'll remove the network and research more. I'm sure I've seen that this is common practise, but I can't fault your logic and learning from others is what this forum is for after all.
Linear voltage regulator: how to make good use of "sense" and "ground sense"? NeoY2k Analog Line Level 7 7th September 2008 12:35 AM
PR Calcs jwatts Subwoofers 0 30th May 2006 11:04 PM
whats up with these SNF calcs? lemans23 Multi-Way 5 29th October 2005 07:03 PM
frustrated with calcs sparky3489 Car Audio 33 3rd October 2005 06:26 AM
BSC calcs Dave Jones Multi-Way 1 27th March 2005 05:38 AM
Copyright 1999-2017 diyAudio
