Soft start question
Soft start question
Old 22nd January 2017, 12:20 PM   #81
R.I.P.
I never received a clear yes or no on this question and may have missed the answer somewhere.
A mains powered appliance can be either ClassII (double insulated) or ClassI, with mandatory PE protection that we are able to build.
Is your project mains powered?
regards Andrew T.
Old 22nd January 2017, 02:46 PM   #82
Less Opinion is offline Less Opinion  United States
Less Opinion's Avatar
Yes.
Old 22nd January 2017, 04:05 PM   #83
R.I.P.
Then you should be building it to ClassI standard with the PE wire connected directly to the Chassis.
And any exposed conductive parts should be connected to the protected chassis.
regards Andrew T.
Old 22nd January 2018, 11:46 PM   #84
troystg is offline troystg  United States
troystg's Avatar
Silly question but can this be used with an SMPS power supply or is it strictly for linear power supplies? I want the momentary push button functionality but not the resistor / thermistor switched in and out of the mains. More of an off / on of the mains.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 23rd January 2018, 07:36 AM   #85
Mooly's Avatar
Soft start question
SMPS are not usually used with a conventional soft start, in fact in some cases to do so could cause problems and even damage. The lower the AC voltage applied to an SMPS, the more current it will in fact draw as it attempts to keep the power delivered to the load constant.
SMPS do have a 'soft start' but it is integral with the electronics driving the switching elements and operates in a totally different way by controlling and restricing the duty cycle of the drive waveform.
Old 23rd January 2018, 10:29 AM   #86
troystg's Avatar
Exactly, that's what I thought and why I asked to be sure.
So anyone know of a push button momentary switch solution for turning on amps?
Troy
Soft start questionHide this!Advertise here!
soft start and delay start - help please cl1238 Tubes / Valves 6 5th January 2016 08:46 AM
Soft Start Help munty76 Parts 0 14th February 2013 02:00 PM
Question Regarding Soft-Start J.R.Freeman Power Supplies 22 30th September 2010 01:43 AM
Soft start question a.wayne Solid State 39 8th November 2009 05:34 AM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
