Soft start question
Soft start question
Old 11th January 2017, 09:05 AM   #21
R.I.P.
Something is wrong.
You should not be reading 130Vac or similar when first connecting and not when it is controlled to OFF.
Disconnect from the mains, disconnect from the transformer.
report the measurements I suggested.
regards Andrew T.
Old 11th January 2017, 11:01 AM   #22
Liliya is offline Liliya  Norway
Thanks Andrew. The measurement you suggested, is it with the Soft Starter standing alone and not connected to transformer/condenserbank?
Eivind S
Old 11th January 2017, 11:04 AM   #23
R.I.P.
yes, completely disconnected.
We need you to confirm the correct purpose of each input connector. Then we can advise on how to wire it up.
regards Andrew T.
Old 11th January 2017, 10:00 PM   #24
The unit I tested yesterday has stopped working. No click, no red led light when the momentary switch was activated.
Luckily I have a newer version very simular with a three legs led instead of a two legs red.
No mains power connected:
Between the two N terminals: O.L Between the two L terminals 0 ohm.
Mains power ON but momentary switch OFF:
Between the two 220 V in: 230V AC Between the two 220V out: 230v AC
The red led light up.
Momentary switch ON:
Between the two 220V in: 230V AC Between the two 220V out:230V AC.
The green led lights up. I can both hear/ feel the relay click with my finger tip.
The momentary switch OFF:
The red led lights up. A new click from the output relay was heard/felt
230v AC on both 220V in and out.
I will wait until Andrews comments to connect this unit to the V3 power unit.
Eivind S
Old 11th January 2017, 10:29 PM   #25
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
Soft start question
since that circuit is isolated from mains, you can test it for function....
mine is the forum soft starter ckt....
surely the traffo provided will have its primary dc resistance in the near thousand ohms.
can be on all the time. as long as the IEC mains connectors are plugged in....
didn't that come with documentation? i will not buy anything
without proper documentation so buyers beware....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 11th January 2017, 10:44 PM   #26
TonyTecson's Avatar
Soft start question
i think all information is in your post #1....
you should be able to use this board......
in your ebay board one relay shorts out a bank of NTC's
while another relay opens the circuit in case of thermal overload,
this is the reason for two relays...2 heat sensors one for each channel
sink....
so one relay is operated normally open while the other is normally closed
found this in the net.....the difference is there is a delay from the time you push the switch, about a second, to the closing of the normally open relay....almost instantaneous.....
the unit is wired this way.....
Old 12th January 2017, 05:41 AM   #27
R.I.P.
What was the resistance between Live and Live, when all was disconnected?
AJT,
the earlier posts had virtually agreed that the first relay was to allow remote low voltage power ON. And the second relay was for the soft start to bypass the added resistance.
regards Andrew T.
Old 12th January 2017, 06:28 AM   #28
0 ohm.
Eivind S
Old 12th January 2017, 07:20 AM   #29
TonyTecson's Avatar
Soft start question
Liliya, can you post picture of the copper side of the board please?
Old 12th January 2017, 07:30 AM   #30
TonyTecson's Avatar
Soft start question
Originally Posted by Mooly View Post
I see a 555 timer on the sheet.
So you apply mains and nothing happens. You then short the contacts and the unit operates...
Then what ? Do have to remove the mains input to reset back to off or does the momentary switch (yes that's what that symbol seems to show) turn the unit off ?
I would also as a safety precaution make sure that the momentary contacts are isolated from the mains. Is that a mains transformer in the middle powering it all ?
with isolation transformer used, the momentary, normally open switch is in no danger of causing shocks......i have some....
Soft start questionHide this!Advertise here!
soft start and delay start - help please cl1238 Tubes / Valves 6 5th January 2016 08:46 AM
Soft Start Help munty76 Parts 0 14th February 2013 02:00 PM
Question Regarding Soft-Start J.R.Freeman Power Supplies 22 30th September 2010 01:43 AM
Soft start question a.wayne Solid State 39 8th November 2009 05:34 AM
Soft start & Soft Switch circuit: can anybody help? m.parigi Solid State 95 22nd August 2005 03:32 PM
