Help needed for building LI-Ion 9volt battery charger
Old 21st February 2016, 08:01 AM   #1
bwolf is offline bwolf  India
Default Help needed for building LI-Ion 9volt battery charger
how to build charger circuit for
9 volt li ion battery.600mah
I read somewhere on the net
you should not charge a battery with a higher voltage than its capacity.
so it must be< 8 - 9V
??charging batteries with 10% of their current. Is this true? Should I be resisting my current to 60mah? my battery capacity 600mah.
external adapter 15v 1.5amp, I have Linear voltage 9v regulator but I dont know how to control current / limit it to 60 mah??
sorry for my bad English
Thank you
Old 21st February 2016, 08:23 AM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Hi, maybe configure a 78XX as a current source ?!
Old 21st February 2016, 08:48 AM   #3
Li batteries can easily be damaged by bad charging.
They are VERY intolerant of the incorrect charging rate/time/temperature.
Stay with lead/acid or NiCad or Nimh if you want easy to charge batteries.
regards Andrew T.
Old 21st February 2016, 08:48 AM   #4
thanks for the Circuit diagram
frnd can you explain Io = (VO/R1) + Io Bias current ??? with my requirements pls
how to get desired out put current with above circuit ?
in general how to get desired out put current??
Old 21st February 2016, 08:59 AM   #5
Yes, that circuit is what I used with Ni/Cd many years ago.
I wouldn't mess with Li-ion because it's very over-my-head
( I've been looking for anything related to electric bikes last year...some sites were displaying some circuits -most ready-made/available on the market -and were intended for RC cars/planes)
Old 21st February 2016, 10:26 AM   #6
basreflex is offline basreflex  Spain
LI-ion 9V are most likely dual cell batteries at 8.4V (2x4.2). applying a current limited voltage higher than 8.4V will destroy the cell or shorten it's life considerably.
so a precision current limited voltage source is needed. a standard 9V NIcd cell charger will not do the job as that one has a much higher voltage. one option is to build a precision shunt using a TL431set at 8.4V, and charge using a voltage with series resistor as limiter.
Old 21st February 2016, 11:22 AM   #7
nathanpc is offline nathanpc  Brazil
nathanpc's Avatar
If you're not experienced with Li-Ion charging I would recommend getting a charge controller for them, you can buy them really cheap on eBay. Lithium cells are pretty intolerant of bad charging, so if you don't understand their charging cycle it's definitely not recommended to build your own charger.
If you want to learn more about LiPo charging I highly recommend you to watch this EEVBlog video.
Projects: Power12 - Mini12 - Mini6 - MintyUSBoost
Old 21st February 2016, 06:16 PM   #8
Thank you frnds.
May I know how to bring my current down from
0.8A to 60 mA??
Or 1.5amp to 60mA ?
Old 24th February 2016, 02:47 PM   #9
how to calculate this
Io = (VO/R1) + Io Bias current??
help me components needed ?
i have lm7808, lm7809 regulators
im noob here. :-/
thank you
2cell li ion 8.4v (9volt)
Old 25th February 2016, 01:24 AM   #10
trobbins is offline trobbins  Australia
trobbins's Avatar
bwolf, what is Io bias from the datasheet for the device you want to use?
Have you looked at the tutorials for the LM317 device?
Help needed for building LI-Ion 9volt battery chargerHide this!Advertise here!
Need circuit for Li-ion baterry charger 3,7V 1500mAh DANIEL SPASOVSKI Everything Else 3 21st January 2011 06:52 AM
Li-Ion Charger Using Max 1555 samkim Power Supplies 8 14th December 2010 06:30 AM
Caps for Li-Ion battery? MikeyBikey Class D 0 12th July 2009 05:09 PM
Battery Charger for 15V Li-ION Battery Pack ??? Jan Dupont Parts 2 11th April 2009 03:18 PM
