Using an LM317/Lm337 PCB to make a zener regulated or capacitance multiplier supply
I was able to "hack" a lm317/lm337 pcb to make it work with a simple zener regulated power supply as well as a simple capacitance multiplier power supply. Its actually not much of work due to similarities in their supplies. I have uploaded the sim results and articles on my site, these are a little large files and I suspect the server is a little slow, so a little bit of patience will help. I am still trying to figure out some ripple measurement system using soundcards and will post results once I have some actual measurements.
http://bluesmagicaudio.com/bma/articles.html
Hello, would you please explain the purpose of diode D8? It is between the base and the emitter of the Darlington pass transistor.
Thank you!!
_
