Isolated sub chassis - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 17th November 2015, 02:57 PM   #1
Bibio is online now Bibio  Scotland
Bibio's Avatar
Default Isolated sub chassis
i'm in the process of designing my new casework and i have a question about power supply PE and component COM (ground).
if the chassis has PE and i put an isolated sub chassis for the electronics (headphone amp and RPi) do i still need to connect COM to the isolated sub chassis?
the only cabling that will be going into the case is from AC power. the RPi will be via wifi and then straight to headphone amp so no external phono connections. other things such as USB sockets and headphone socket will be isolated from the main chassis.
Old 17th November 2015, 03:27 PM   #2
JonSnell Electronic's Avatar
Send a message via Skype™ to JonSnell Electronic
As a rule, any metalwork unless doubly insulated must be earthed.
Support for Flying Mole Class D, Allen & Heath, Valve amps, older designs & 2CVs. www.jonsnell.co.uk
Old 17th November 2015, 03:38 PM   #3
Bibio's Avatar
isolated 'plate' will be on non conductive standoffs. casework will be made from stainless steel.
or do you think it would be better just to stick too two cases, one for the PS and the other for the electronics with DC power via umbilical?
Do Bridge rectifier blocks need to be isolated from chassis? Hikari1 Pass Labs 4 30th March 2013 06:30 AM
Isolated vs non-isolated DC converters for car audio amplification Stonner Power Supplies 5 17th July 2012 03:23 AM
isolated or non-isolated psu for UcD in a car? zilog Class D 1 2nd February 2009 03:56 AM
What is the difference between an isolated IC and a non-isolated IC? DJ Exprice Chip Amps 16 20th June 2006 07:34 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
