Power relay - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th October 2015, 02:16 PM   #1
Default Power relay
Anyone know how to test this ?
I need to see if it's defective or not
Any info would be appericated
Old 20th October 2015, 03:54 PM   #2
sofaspud's Avatar
What is this a part of?
10A @ 120VAC... How worried should we be of your safety?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 20th October 2015, 03:58 PM   #3
JonSnell Electronic's Avatar
Here is the data sheet on it;
http://www.farnell.com/datasheets/165880.pdf
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 20th October 2015, 07:38 PM   #4
If I take the brown and blue wires off this and touch the terminals I should get a reading across them to see if the coil is open correct ..
If so would this be a reliable test or not ?
Old 20th October 2015, 08:02 PM   #5
sofaspud's Avatar
Yes. Unplug the entire thing from the outlet, remove those wires, and measure the coil resistance.
I don't see an AFM220-330 in the catalog JSE linked to, but you should be able to make a reliable comparison with the data provided.
Old 21st October 2015, 10:59 PM   #6
I put the Meyer leads across the coil and get a high ohm reading ..
Wondering if this could still be bad since it smells burnt and if o shake it somewhat I can hear stuff rattle around in it
Old 21st October 2015, 11:54 PM   #7
sofaspud's Avatar
Did you compare the coil resistance measured to a similar unit in the datasheet? (Assuming your meter provides digits... hint, hint)
Old 22nd October 2015, 12:02 AM   #8
The discoloration and burning of the power leads indicates the relay and connectors need to be replaced. Soon.
G
Old 22nd October 2015, 12:26 AM   #9
sofaspud's Avatar
Where are you seeing discoloration and burning?
Old 22nd October 2015, 01:36 AM   #10
Haven't compared the readings yet ..
I just see the ends of the wire connecters dis colored the relay also has a burnt smell to it .
Power off pop even using speaker relay redal Chip Amps 5 21st March 2013 11:56 AM
output relay for power amp maxpou Solid State 15 14th May 2012 02:55 AM
Power Relay keaster Power Supplies 6 20th February 2011 07:35 AM
Power relay suppliers in canada ruerose The Lounge 1 15th June 2007 08:24 PM
Relay for power on ThSpeakerDude88 Car Audio 13 1st October 2006 08:37 PM
Copyright 1999-2017 diyAudio
